I added a Coral TPU (USB) to my HA blue, but it's not detected by HA and Frigate will not start, if I add CPU as a detector everything works fine, so I know my Frigate is working fine but off course uses too many resources so want to move to a Coral as a detector, any idea what I'm missing here?
detectors:
coral:
type: edgetpu
device: usb
Do I need to add separate drivers for this? If I read the release notes of the OS version, I see this, so seems it should work?
Google Coral PCIe AI Accelerator Support
@ryddler enabled the driver for Google Coral PCIe TPU devices. This allows to use Google Coral Mini PCIe Accelerator or M.2 Accelerator on all boards supporting PCIe.
That’s all Folks! Now go out and update!
Version information
System Health
version: core-2021.8.2
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.6
os_name: Linux
os_version: 5.10.53
arch: aarch64
timezone: Europe/Brussels
GitHub API: ok
Github API Calls Remaining: 4196
Installed Version: 1.13.2
Stage: running
Available Repositories: 909
Installed Repositories: 40
logged_in: true
subscription_expiration: 26 augustus 2021 02:00
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: false
google_enabled: true
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 6.2
update_channel: stable
supervisor_version: supervisor-2021.06.8
docker_version: 20.10.6
disk_total: 113.9 GB
disk_used: 12.4 GB
healthy: true
supported: true
board: odroid-n2
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.5.1), Visual Studio Code (3.6.1), deCONZ (6.9.0), Samba Backup (4.5.0), Assistant Relay (0.7.4), ADB - Android Debug Bridge (0.8.0), Tautulli (2.3.0), Node-RED (9.2.1), Mosquitto broker (6.0.1), File editor (5.3.3), MariaDB (2.4.0), Eufy Home Assistant MQTT Bridge (1.21.0), Frigate NVR (1.13)
Thanks in advance!
