Coral USB crashes lately
Hi there,
I don’t know if this fits in here or belongs to rather the hardware or the configuration section but I currently face this issue:
It seems like one of the more recent OS upgrades (somewhere between 7.0 and 7.2 I think) somehow causes my Coral USB device to crash as soon as the first detection in frigate is triggered.
I can rule out frigate and the Coral device being faulty since they both are running fine on another device with the same version.
Also I can rule out the USB port of my NUC which everything runs from directly so no virtualization layer in between. I tested another USB device on the port (ZWave Stick) and it runs perfectly fine. Also tested every other port on the device and the Coral crashes on all of them.
Also before one of the mentioned OS upgrades the device was working flawless.
I got in touch with the Frigate developer but the issue seems not related to frigate. Also I installed several versions, also some which I know worked and it still crashed.
So once a detection is triggered in there sometimes it works once (if I’m lucky) and right then it will crash with an USB error message:
F driver/usb/usb_driver.cc:406] HandleEvent failed. USB transfer error 1 [LibUsbDataInCallback]
Fatal Python error: Aborted
Thread 0x00007f7ed794d700 (most recent call first):
  File "/usr/lib/python3.8/threading.py", line 302 in wait
  File "/usr/lib/python3.8/multiprocessing/queues.py", line 227 in _feed
  File "/usr/lib/python3.8/threading.py", line 870 in run
  File "/usr/lib/python3.8/threading.py", line 932 in _bootstrap_inner
  File "/usr/lib/python3.8/threading.py", line 890 in _bootstrap
Thread 0x00007f7ee851e740 (most recent call first):
  File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 833 in invoke
  File "/opt/frigate/frigate/edgetpu.py", line 84 in detect_raw
  File "/opt/frigate/frigate/edgetpu.py", line 160 in run_detector
  File "/usr/lib/python3.8/multiprocessing/process.py", line 108 in run
  File "/usr/lib/python3.8/multiprocessing/process.py", line 315 in _bootstrap
  File "/usr/lib/python3.8/multiprocessing/popen_fork.py", line 75 in _launch
  File "/usr/lib/python3.8/multiprocessing/popen_fork.py", line 19 in __init__
  File "/usr/lib/python3.8/multiprocessing/context.py", line 277 in _Popen
  File "/usr/lib/python3.8/multiprocessing/context.py", line 224 in _Popen
  File "/usr/lib/python3.8/multiprocessing/process.py", line 121 in start
  File "/opt/frigate/frigate/edgetpu.py", line 221 in start_or_restart
  File "/opt/frigate/frigate/edgetpu.py", line 190 in __init__
  File "/opt/frigate/frigate/app.py", line 197 in start_detectors
  File "/opt/frigate/frigate/app.py", line 340 in start
  File "/opt/frigate/frigate/__main__.py", line 17 in <module>
  File "/usr/lib/python3.8/runpy.py", line 87 in _run_code
  File "/usr/lib/python3.8/runpy.py", line 194 in _run_module_as_main
So looking at the first line it looks like something is not right with the USB driver or am I wrong?
Is there anything known or does anyone experience a similar issue?
Did anyone manage to fix this somehow?
I’m searching for a solution for weeks now but don’t get anywhere so I hope somebody in here might have an idea or at least has some similar issue so it might be worth opening a bug report for HA?
Thanks a lot!
Have you been able to fix this? I am running this in docker thats on ubuntu on Mac mini … tried different cables and the one that comes with it. No difference
For me it was a hardware problem. I replaced all cables and plugs and it worked afterwards. So it was one of them which didn’t work but only with the coral somehow.
