i am running HassOS on an old laptop.
recently i tried to install Eufy mqtt bridge from GitHub - MaxWinterstein/homeassistant-addons
but it refuses to install because Supervisor is unhealthy. tried these commands but nothing works:
ha supervisor repair
ha supervisor update and got these errors:
these are some errors i in my logs
supervisor error
22-02-01 15:17:33 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bus/usb/004/091 - None
22-02-01 15:17:33 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/bus/usb/004/091 - None
22-02-01 15:17:33 WARNING (MainThread) [supervisor.hardware.monitor] Ignore device /sys/devices/pci0000:00/0000:00:06.0/usb4/4-3/4-3:1.0/0003:05AC:0236.27BC/input/input5096/event10 / failes to initialize by udev
22-02-01 15:17:33 WARNING (MainThread) [supervisor.hardware.monitor] Ignore device /sys/devices/pci0000:00/0000:00:06.0/usb4/4-3/4-3:1.0/0003:05AC:0236.27BC/hidraw/hidraw0 / failes to initialize by udev
22-02-01 15:17:33 WARNING (MainThread) [supervisor.hardware.monitor] Ignore device /sys/devices/pci0000:00/0000:00:06.0/usb4/4-3/4-3:1.1/0003:05AC:0236.27BD/hidraw/hidraw1 / failes to initialize by udev
core
2022-02-01 11:42:53 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/f1c878cb_eufy-ha-mqtt-bridge/install - ‘AddonManager.install’ blocked from execution, system is not healthy
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
2022-02-01 11:43:48 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/shutdown request Server disconnected
2022-02-01 11:43:48 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /host/shutdown -
[finish] process exit code 0
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
