Hi all,
I am running core-2021.6.6 on Home Assistant OS 6.1 (on a pi4). I have a ConBee II with firmware 266b0700.
I have recently had an issue where none of my zigbee sensors were updating and found that deconz had not been working. After a full shutdown and restart of HA everything seemed to work okay for a number of days. But again today i noticed things again not working correctly. When i went in to deconz via the vnc plugin i noticed none of my devices had any connections between them. Then when i looked at the supervisor i see the following error messages every second.
21-06-28 19:36:26 ERROR (MainThread) [supervisor.api.middleware.security] Invalid token for access /hardware/trigger
21-06-28 19:36:27 WARNING (MainThread) [supervisor.api.middleware.security] core_deconz missing API permission for /hardware/trigger
Looking in the deconz ha documentation it mentions to check you have the latest firmware (which i have done) and the latest software. I have the latest available HA OS and core versions.
I have restarted the deconz docker container and performed a full shutdown and restart of the pi but still no luck.
I have not really debugged deconz in the past and not sure exactly where to start to resolve these errors. Has anyone seen these errors before?
