I have followed the correct steps to set my IP address (usb stick, CONFIG directory, etc) to set my ip address to 192.168.10.55.
After verifying the correct procedure has been followed (including running “os import” command to force update from usb stick), the ip_address value still remains as 172.30.32.1 no matter what I do.
The web (192.168.10.55:8123) interface shows “404 error”, which is weird. However the “core info” command shows a clear mismatch in the IP address, clearly representing the ip_address value for hassio as being “172.30.32.1”.
If anyone could provide direction it would be greatly appreciated.
I have extensively searched this topic, but clearly missed something - my thanks in advance to anyone with insight.
Brett
