I’m running HA on an RPi4 with 4GB of RAM. OS version is 12.2. Current Core version is 2024.3.3
Trying to troubleshoot why Core will not update, but having issues with the Suervisor log.
(I am currently unable to update core, it just appears not to run, and I am unable to troubleshoot, because it appears something is broken with HA Supervisor. Here’s an example of what my HA Supervisor log looks like:
File "/usr/src/supervisor/supervisor/bootstrap.py", line 108, in <lambda>
logging.Formatter.converter = lambda *args: coresys.now().timetuple()
File "/usr/src/supervisor/supervisor/coresys.py", line 525, in now
return datetime.now(get_time_zone(self.timezone) or UTC)
File "/usr/src/supervisor/supervisor/utils/dt.py", line 73, in get_time_zone
return zoneinfo.ZoneInfo(time_zone_str)
File "/usr/local/lib/python3.12/zoneinfo/_common.py", line 28, in load_data
header = _TZifHeader.from_file(fobj)
File "/usr/local/lib/python3.12/zoneinfo/_common.py", line 146, in from_file
raise ValueError("Invalid TZif file: magic not found")
ValueError: Invalid TZif file: magic not found
Call stack:
File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self._bootstrap_inner()
File "/usr/local/lib/python3.12/threading.py", line 1073, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.12/threading.py", line 1010, in run
self._target(*self._args, **self._kwargs)
Message: 'Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version 2024.3.3'
Arguments: None
--- Logging error ---
File "/usr/local/lib/python3.12/logging/__init__.py", line 1160, in emit
msg = self.format(record)
File "/usr/local/lib/python3.12/logging/__init__.py", line 999, in format
return fmt.format(record)
File "/usr/local/lib/python3.12/logging/__init__.py", line 705, in format
record.asctime = self.formatTime(record, self.datefmt)
File "/usr/local/lib/python3.12/logging/__init__.py", line 640, in formatTime
ct = self.converter(record.created)
Call stack:
self.run()
Message: 'Wait until Home Assistant is ready'
Arguments: None
Call stack:
self.run()
Message: 'Home Assistant Core state changed to NOT_RUNNING'
Arguments: None
Is there a way to fix the above issues relating to output a timestamp?
