My system seems to be unhealthy. When I try to update the Core it gets stuck in an infinite loop.
When I try to update the OS I get the error message:
“Error updating Home Assistant Operating System: ‘OSManager.update’ blocked from execution, system is not running - CoreState.STARTUP”
Seems that the System is not able to start the core propperly. How to fix that?
System Information
version | core-2022.11.1
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
virtualenv | false
python_version | 3.10.7
os_name | Linux
os_version | 5.15.67
arch | x86_64
timezone | Europe/Berlin
config_dir | /config
Home Assistant Supervisor
host_os | Home Assistant OS 9.0
update_channel | stable
supervisor_version | supervisor-2022.11.0
agent_version | 1.3.0
docker_version | 20.10.17
disk_total | 19.0 GB
disk_used | 13.0 GB
healthy | true
supported | true
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Node-RED (13.3.2), Terminal & SSH (9.6.1), File editor (5.4.1), Mosquitto broker (6.1.3), Duck DNS (1.15.0), NGINX Home Assistant SSL proxy (3.1.5)
