Core Update Failure 2022.11.2
I’ve been trying to update from 2022.11.2 for several days now. I’ve been consistently getting this failure when trying to go to either 2022.11.3 or 2022.11.4. Any suggestions?
22-11-21 11:11:49 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2022.11.4
22-11-21 11:11:49 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.2 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4
22-11-21 11:11:49 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.11.4.
22-11-21 11:18:18 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-11-21 11:18:18 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-11-21 11:18:40 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-11-21 11:18:40 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-11-21 11:19:11 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-11-21 11:19:11 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-11-21 11:19:53 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-11-21 11:19:53 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-11-21 11:20:04 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4/json: Not Found ("no such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4: No such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4")
22-11-21 11:20:04 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
I am also having the same issue, tried uninstalling all add-one and no luck.
I think the version update sensors were updated with the new releases before the images and release notes were in place, so give it a little time.
The release notes seems to just have come online now, but the sensors were updated several hours ago.
Still not updating.
Same here. Appreciate any guidance. Stuck updating core from 2022.11.2 to 2022.11.3 then managed to avoid that and now I’m in the same situation trying to move from 2022.11.2 to 2022.11.4!
One would assume these stable releases would be… tested and stable?
I thought I read something about Unifi being the trouble area, but the update just sits there spinning.
If it is still not updating then something is wrong.
A common issue seems to be the DNS service, so try to run “ha resolution info” in the ha cli to see what it feels you.
Having a similar issue but it seems that the GitHub server is not available.
22-11-25 09:54:41 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2022.11.4
22-11-25 09:54:41 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.2 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4
22-11-25 09:54:41 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.11.4.
22-11-25 09:54:56 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.11.4&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/raspberrypi4-64-homeassistant/manifests/2022.11.4": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fraspberrypi4-64-homeassistant%3Apull&service=ghcr.io": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
22-11-25 09:54:56 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
22-11-25 09:57:59 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2022.11.4
22-11-25 09:57:59 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.2 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4
22-11-25 09:57:59 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.11.4.
22-11-25 09:58:11 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.11.4&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("received unexpected HTTP status: 503 Service Unavailable")
22-11-25 09:58:11 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
2
I’m kind of relieved I am not the only one getting exactly this error. I can only hope it’s a temporary issue :smile:
EDIT:
it’s working for me now, just started the update via console
same here. log into HA via ssh, then start the update with
ha core update
I’ve tried updating using ha core update from an SSH session, but it still fails.
22-12-01 11:16:31 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2022.11.5
22-12-01 11:16:31 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.2 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.5
22-12-01 11:16:31 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.11.5.
22-12-01 11:25:05 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.5: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.5/json: Not Found ("no such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.5: No such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.11.5")
22-12-01 11:25:05 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
Any other suggestions?
Have patience.
HA is consisting of a rather large user base and both HA, HACS and most of the other integrations and addons rely on GitHub for distribution, so it can be hammered at times when there are many updates especially of the HA core.
