I’m struggling to update Core to 2024.12.5 (from 2024.5.3) for a few days now. After a while it just reboot and nothing else. I can’t see anything relevant in the logs.
I also trying to update from terminal to 2024.6.1 but I got the same behavior.
Do you have an idea how to get unstuck? Or where to check what’s going wrong?
it may simplify things if you just slowly do the monthly upgrade (june, july…november) and when you hit version where it does not start check the breaking changes for that version against the integrations you are using. You wont need to do every version for each month just the first release or last release for each month.
EDIT
somehow missed you already tried 2024.6
there are still some breaking changes 5 to 6
are you using core in docker? how did you install?
if it is not starting there will be something in log so post log if you can.
