I’ve been trying to install the latest core update 2024.11.1, but without any luck. I tried it through the “normal way” as well as through terminal using the ha core update command. Doing it the through the HA home page, it will make a backup, and then start loading to install the update. Without any errors or messages it stops loading, after which the message goes back to “update available”.
Related to this? Cannot install supervisor 2024-11-3 hassos - #26 by tom_l
No, I didn’t have any problems with updating the supervisor. I’m running on 2024.11.3 all fine. The weird thing is that there are no error messages. Running the command returns “command completed successfully”. It is currently running on core 2024.10.3. I even tried updating to 2024.10.4, but also that did not work.
Same problem here.
I was on 2024.9.3 and updating to 2024.11.1 didn’t result in any obvious errors in the interface or logs.
When booting back up it briefly shows 2024.11.1 in the about page and shortly after it rolls back to 2024.9.3.
Upgrading to version 2024.11.0 also does not work.
Since @DylanS is on 2024.10.3, I tried upgrading to that version.
It says the command succesfully completed but then rolls back to 2024.9.3.
The core logs don’t show anything before the reboot back into 2024.9.3.
The logs begin with the database migration warnings.
I also tried booting into safe mode and the upgrading but that didn’t help either.
Tried upgrading to 2024.11.2 to see if it fixed the issue but unfortunately not.
The only thing I can find in the logs is this in the supervisor logs:
Tried looking at the core or host logs too but couldn’t find any clues there either.
I’m on version 2024.10.4.
Can’t update too. After Reboot am back on 2024.10.4 instead of 2024.11.3.
I am having the same issue with the update. I am stuck on 2024.10.4.
I found the cuprit, at least for my installation.
Check the home-assistant-rollback.log file.
There the error can be found.
For me it is a custom vacuum integration that misses an attribute.
For other people on Github, it was an ID that was incorrect in a storage file.
