CoreDNS plugin constantly reloads
Hi.
CoreDNS plugin constantly reloads.
In logs I see:
Aug 23 09:26:02 rock64 hassio-supervisor[1990]: 19-08-23 04:26:02 INFO (SyncWorker_2) [hassio.docker.dns] Start DNS homeassistant/aarch64-hassio-dns with version 1
Aug 23 09:26:02 rock64 hassio-supervisor[1990]: 19-08-23 04:26:02 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with CoreDNS plugin!
Aug 23 09:26:02 rock64 hassio-supervisor[1990]: 19-08-23 04:26:02 WARNING (MainThread) [hassio.tasks] CoreDNS plugin is in fails state / Reset config
Aug 23 09:26:02 rock64 hassio-supervisor[1990]: 19-08-23 04:26:02 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
Aug 23 09:26:02 rock64 hassio-supervisor[1990]: 19-08-23 04:26:02 INFO (SyncWorker_2) [hassio.docker.interface] Clean hassio_dns application
Aug 23 09:26:26 rock64 hassio-supervisor[1990]: 19-08-23 04:26:26 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with CoreDNS plugin!
Aug 23 09:26:26 rock64 hassio-supervisor[1990]: 19-08-23 04:26:26 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
Aug 23 09:26:26 rock64 hassio-supervisor[1990]: 19-08-23 04:26:26 ERROR (MainThread) [hassio.utils] Can't execute run while a task is in progress
Aug 23 09:26:38 rock64 hassio-supervisor[1990]: 19-08-23 04:26:38 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with CoreDNS plugin!
Aug 23 09:26:38 rock64 hassio-supervisor[1990]: 19-08-23 04:26:38 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
Aug 23 09:26:38 rock64 hassio-supervisor[1990]: 19-08-23 04:26:38 ERROR (MainThread) [hassio.utils] Can't execute run while a task is in progress
Please help, what kind of problem do I have?
I have the same issue on the rock64 haven’t figured it out yet. HomeAssistant also will not connect to external services.
