Coronavirus Vaccination Count Sensor
I currently use the Coronavirus integration for stats and it works great, but I think it’d be better if we could also get a vaccine count to go alongside it.
I’ve tried setting this up as a sensor using scrape but I’ve never done it before and I’m getting nowhere.
The data for the UK is available here (which is what I’m trying to get), taken from a list of available sources here.
I’m reading the documentation for scrape sensors and such to try get this working, however I was wondering if anyone already has a working example?
Edit: There’s also a CSV available here - I’m wondering if that’d be easier to parse for Home Assistant?
For anyone interested, I eventually noticed there’s an API to be used for this.
- platform: rest
  resource: https://api.coronavirus.data.gov.uk/v1/data?filters=areaType=overview&structure={%22date%22:%22date%22,%22newPeopleVaccinatedFirstDoseByPublishDate%22:%22newPeopleVaccinatedFirstDoseByPublishDate%22,%22newPeopleVaccinatedSecondDoseByPublishDate%22:%22newPeopleVaccinatedSecondDoseByPublishDate%22,%22cumPeopleVaccinatedFirstDoseByPublishDate%22:%22cumPeopleVaccinatedFirstDoseByPublishDate%22,%22cumPeopleVaccinatedSecondDoseByPublishDate%22:%22cumPeopleVaccinatedSecondDoseByPublishDate%22}
  json_attributes_path: "$.[0]"
  json_attributes:
    - date
    - cumPeopleVaccinatedFirstDoseByPublishDate
    - cumPeopleVaccinatedSecondDoseByPublishDate
    - newPeopleVaccinatedFirstDoseByPublishDate
    - newPeopleVaccinatedSecondDoseByPublishDate
  value_template: "{{ value_json['data'][0]['cumPeopleVaccinatedFirstDoseByPublishDate'] }}"
Here are some of the template sensors.
  sensors:
    firstdose:
      friendly_name: "First Dose"
      value_template: "{{ '{0:,.0f}'.format(state_attr('sensor.vaccinations', 'cumPeopleVaccinatedFirstDoseByPublishDate')) }}"
    seconddose:
      friendly_name: "Second Dose"
      value_template: "{{ '{0:,.0f}'.format(state_attr('sensor.vaccinations', 'cumPeopleVaccinatedSecondDoseByPublishDate')) }}"
    vaccinedate:
      friendly_name: "Data Last Updated"
      value_template: "{{ (state_attr('sensor.vaccinations', 'date')) }}"
    populationfirstvaccination:
      friendly_name: "Percentage received first dose"
      value_template: "{{ ((state_attr('sensor.vaccinations', 'cumPeopleVaccinatedFirstDoseByPublishDate')) | float / 52632729 * 100) | round }}"
      unit_of_measurement: '%'
    populationsecondvaccination:
      friendly_name: "Percentage received second dose"
      value_template: "{{ ((state_attr('sensor.vaccinations', 'cumPeopleVaccinatedSecondDoseByPublishDate')) | float / 52632729 * 100) | round }}"
    newfirstdose:
      friendly_name: "Daily Vaccinations (First dose)"
      value_template: "{{ '{0:,.0f}'.format(state_attr('sensor.vaccinations', 'newPeopleVaccinatedFirstDoseByPublishDate')) }}"
    newseconddose:
      friendly_name: "Daily Vaccinations (Second dose)"
      value_template: "{{ '{0:,.0f}'.format(state_attr('sensor.vaccinations', 'newPeopleVaccinatedSecondDoseByPublishDate')) }}"
Which I’ve formatted to look like this on the frontend
Just a basic entity card.
type: entities
entities:
  - entity: sensor.vaccinedate
    icon: 'mdi:update'
    name: Data last published
  - entity: sensor.firstdose
    icon: 'mdi:needle'
    name: Total received first dose
  - entity: sensor.seconddose
    icon: 'mdi:needle'
    name: Total received second dose
  - entity: sensor.newfirstdose
    icon: 'mdi:counter'
    name: New first doses
  - entity: sensor.newseconddose
    icon: 'mdi:counter'
    name: New second doses
  - entity: sensor.populationfirstvaccination
    icon: 'mdi:account-multiple-check'
    name: Percentage received first dose
  - entity: sensor.populationsecondvaccination
    name: Percentage fully vaccinated
title: COVID-19 Vaccinations UK
Thanks for the inspiration Tom. I’ve set up a vaccine count for my city of Philadelphia, PA based on your example.
I get the data from the City of Philadelphia’s Open Data Explorer for Covid-19 and like you, created an entity using the REST API in Home Assistant.
vaccinations
- platform: rest
  resource: 'https://phl.carto.com/api/v2/sql?q=SELECT%20*%20FROM%20covid_vaccine_totals'
  name: PHL Vaccinations
  scan_interval: 3600
  json_attributes_path: "$.rows[0]"
  json_attributes:
    - total_count
    - first_dose
    - second_dose
    - etl_timestamp
  value_template: "{{ value_json['rows'][0]['total_count'] }}"
Cool! Glad to have helped in some fashion.
Just brilliant :grinning:
Something not quite right with the date.
[edit]
That is the date returned by the API - doesn’t match the dashboard date though.
[edit]
Obvious really, the date is the data date rather than the ‘published’ date so on the 22nd you are seeing the data from the 21st. You could not really expect it any quicker but using ‘published’ date is a little misleading.
Agreed, this could be worded better. Sorry for the confusion.
No bother. The official site doesn’t make it that clear really.
Here’s something similar for Belgium.
YAML sensors:
  - platform: rest
    name: COVID Vaccinatie BE - Last Updated
    resource: https://covid-vaccinatie.be/api/v1/last-updated.json
    value_template: '{{ value_json.result.last_updated.updated }}'
  - platform: rest
    name: COVID Vaccinatie BE - Administered Partially
    resource: https://covid-vaccinatie.be/api/v1/administered.json
    value_template: '{{ value_json.result.administered | sum(attribute="first_dose") }}'
  - platform: rest
    name: COVID Vaccinatie BE - Administered Fully
    value_template: '{{ value_json.result.administered | sum(attribute="second_dose") }}'
  - platform: rest
    name: COVID Vaccinatie BE - Delivered Doses
    resource: https://covid-vaccinatie.be/api/v1/delivered.json
    value_template: '{{ value_json.result.delivered | sum(attribute="amount") }}'
    sensors:
      covid_vaccinatie_be_administered_partially_percentage:
        friendly_name: "COVID Vaccinatie BE - Administered Partially Population Percentage"
        value_template: "{{ ((states('sensor.covid_vaccinatie_be_administered_partially')) | float /11492641*100) | round(1)}}"
      covid_vaccinatie_be_administered_fully_percentage:
        friendly_name: "COVID Vaccinatie BE - Administered Fully Population Percentage"
        value_template: "{{ ((states('sensor.covid_vaccinatie_be_administered_fully')) | float /11492641*100) | round(1) }}"
Lovelace:
type: entities
entities:
  - entity: sensor.covid_vaccinatie_be_last_updated
    icon: 'mdi:update'
  - entity: sensor.covid_vaccinatie_be_delivered_doses
    icon: 'mdi:truck-delivery'
  - entity: sensor.covid_vaccinatie_be_administered_partially
    icon: 'mdi:needle'
    name: Total administered partially
  - entity: sensor.covid_vaccinatie_be_administered_partially_percentage
    icon: 'mdi:chart-timeline-variant'
    name: Percentage administered partially
  - entity: sensor.covid_vaccinatie_be_administered_fully
    icon: 'mdi:needle'
    name: Total administered fully
  - entity: sensor.covid_vaccinatie_be_administered_fully_percentage
    name: Percentage administered fully
title: COVID-19 Vaccinations BE
