Correct nginx config for remote access
need some help getting my HA and nginx config correct.
have my own domain, going thru cloudflare to a local install of nginx
Home Assistant OS as VM in proxmox (192.168.50.14)
Nginx Proxy Manager as LCX in proxmox (192.168.50.17)
have updated HA URL to my own URL and it says “External Access Enabled”
set up proxy host in nginx to point to HA.
accessed HA from URL (from external source) initially i got the 400 error as expected.
this is where i’ve read a lot of conflicting info.
i added the following to the configuration.yaml
http:
    use_x_forwarded_for: true
    trusted_proxies: 192.168.50.17
in nginx i added the following config
also enabled “websockets support”
the issue i now have is that, whilst the HA login page loads fine. 80% of the time when i enter a correct user/password i get bounced back to the login page saying “start over”, using the same user/password when accessing locally has zero issues. the other 20% of the time it does accept the user/password and logs in all ok.
the logs show it as an invalid login attempt, but the it’s not as the user/password is correct
WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 162.158.33.231 (162.158.33.231)
i’m assuming i still have a config issue in either HA or nginx.
can anyone advise?
anyone help?
There’s nothing wrong with HA, if there was then you’d get an error about untrusted proxy.
What does the text of your NGINX config look like?
well clearly something is wrong somewhere, as it’s looping back to “start over” when using a correct user/password when connecting remotely.
not sure what you mean by what the text looks like
i use nginx proxy manager so everything is conigured via the UI
the original post shows the config for the home assistant host.
And it creates a text file that NGINX uses.
That text file is more helpful than some limited screenshots.
map $scheme $hsts_header {
    https   "max-age=63072000; preload";
server {
  set $forward_scheme http;
  set $server         "192.168.50.14";
  set $port           8123;
  listen 80;
listen [::]:80;
listen 443 ssl http2;
listen [::]:443 ssl http2;
  server_name <redacted>;
  # Let's Encrypt SSL
  include /etc/nginx/conf.d/include/letsencrypt-acme-challenge.conf;
  include /etc/nginx/conf.d/include/ssl-ciphers.conf;
  ssl_certificate /etc/letsencrypt/live/npm-4/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/npm-4/privkey.pem;
Nothing there shows websockets are enabled.
sorry just realised i didn’t paste the full file.
2 seconds and i’ll get the full file
server {
  set $port           8123;
  listen 80;
listen [::]:80;
  # Let's Encrypt SSL
  # Block Exploits
  include /etc/nginx/conf.d/include/block-exploits.conf;
    # Force SSL
    include /etc/nginx/conf.d/include/force-ssl.conf;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $http_connection;
proxy_http_version 1.1;
  access_log /data/logs/proxy-host-5_access.log proxy;
  error_log /data/logs/proxy-host-5_error.log warn;
  location / {
proxy_set_header    Connection  "upgrade";
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-Scheme $scheme;
    proxy_set_header X-Forwarded-Proto  $scheme;
    proxy_set_header X-Forwarded-For    $remote_addr;
    proxy_set_header X-Real-IP		$remote_addr;
    set $proxy_forward_scheme http;
    set $proxy_server         "192.168.50.14";
    set $proxy_port           8123;
    proxy_pass       $proxy_forward_scheme://$proxy_server:$proxy_port;
  # Block Exploits
    # Force SSL
  # Custom
  include /data/nginx/custom/server_proxy[.]conf;
i have uploaded the full content of the config file, the original upload wasn’t complete
Thanks.
The indenting is all over the place, but I don’t think that matters for NGINX’s config file. I don’t see any obvious problems.
so what is the cause of the “start over” and a log showing invalid login when i’m using a correct user/pass when attempting to connet remotely?
i just tested it again.
1st attempt resulted in the “start over”.
2nd attempt resulted in a successful login
both attempts used the same user/password.
The only reasons HA has to reject login are:
  1. If the IP is banned
  2. If the credentials are wrong
All I can assume is that there’s something funky going on with NGINX
1st attempt results in the “start over”
this now seems to be reproducable - ie, it’s not as ranom as first thought.
i have been able to reproduce this multiple times now - ie 1st attempt fails, 2nd attempt works.
neither of those would give a “start over” prompt though? they would give the standard “wrong login details” prompt ?
