Correct order of removing integrations & addons
What is a correct order of things to be done to remove integrations/ addons? Typically Google gives total bullshit for answers, and couldn’t find here either.
E.g. stop the addon, delete integration, then uninstall addon ? Restarting in between or not? Or reloading (what)? etc. etc.
I don’t remember what I did wrong last time, but had tons of problems with integration that could not be removed etc.
So, what is in general the right order/ sequence of things?
Hmm… I thought this would be a simple question… How do you guys do it?
i would first remove the integration which is running inside home assistant and move on to add on which is a separate container then ha.
