I’ve got a RF433Mhz device - EV1527 which is a relay that turns on/off lamps in my house (it’s showed in HA as light.rfcustom_524643_0 in my case).
I also have a PZEM004 electricity monitor between the relay and lamp sockets. If I start switching on and off EV1527 the status of the switched lamp may be wrong (the status in HA will be showed wrong - physical light will be ON and the status in HA will be OFF).
How can I set the right status of the relay depending of value from PZEM004 electricity monitor (sensor.pobor_pradu_swiatlo_korytarz_energy_current) - for example if I switch on light the electricity monitor will show that current is 0.2 A [higher than 0], in that case change status of light switch to ON and if current is 0 A then change status to off).
Simply run an automations so that current value below or above threshold => turn on or off the rf433 device. Doesn’t matter if it was already turned on/off manually.
- alias: "Żarówka Wyłączona jeżeli stan z licznika 0A"
- platform: numeric_state
entity_id: sensor.pobor_pradu_swiatlo_korytarz_energy_power
below: 5
for: '00:00:30'
- service: light.turn_off
entity_id: light.rfcustom_524643_0
and
- alias: "Żarówka Włączona jeżeli stan z licznika powyżej 0A"
above: 20
for: '00:00:30'
- service: light.turn_on
Indeed it changes the state of light depending on energy meter but I think there’s another problem - the relay just toggle its status - doesn’t matter if I send light.on or light.off command - with those 2 automations it will keep switch on and off - I wonder if I can bypass it somehow?
Thank You for both replies - when I used the code above the result is that the template light turns on and off the relay but the status of "light by sensor’ entity changes for ON and then it goes OFF each time - I’m not sure if it ‘reads’ the correct value from energy monitor (PZEM-004 has a delay for like 10 sec. after its update itself).
In logs I found:
Update for light.light_by_sensor fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 281, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 459, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/template/light.py", line 272, in async_update
state = self._template.async_render().lower()
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 222, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: '<' not supported between instances of 'str' and 'float'
