I have a bunch of TRVs (appear as climate entities) in a group. I simply want the best way to count how many of these have a hvac_action attribute of heating.
I have it working with
{{ expand('group.active_trvs') | selectattr('attributes.hvac_action', 'eq', 'heating') | list | count}}
which is fine but the docs say
Avoid using
states.sensor.temperature.state, instead usestates('sensor.temperature'). It is strongly advised to use thestates(),is_state(),state_attr()andis_state_attr()as much as possible, to avoid errors and error message when the entity isn’t ready yet (e.g., during Home Assistant startup).
and gives examples like
{{ ['light.kitchen', 'light.dinig_room'] | select('is_state', 'on') | select('is_state_attr', 'brightness', 255) | list }}
but attempting to convert this as
{{ expand('group.active_trvs') | select('is_state_attr','attributes.hvac_action', 'idle') | list | count }}
results in
AttributeError: 'TemplateState' object has no attribute 'lower'
which I guess is because it returns a TemplateState object not a standard State object ??
Also appears hit and miss as to when I need to include the attributes. or not.
I am able to do this using entity_ids using
{% set trvs = [
state_attr('climate.bedroom_thermostat' , 'hvac_action'),
state_attr('climate.lounge_thermostat' , 'hvac_action')
{{ trvs | select ('eq', 'heating') | list | count}}
but I really want to use the group so I can set that dynamically to be different TRVs using the group.set service.
Ultimately what is the best way to create a binary sensor that checks whether any entity currently in the active_trvs group has a hvac_action or heating that won’t error when HA starts etc.
