So i’m trying to create a custom action based on a query to the voice assistant.
I want to be able to turn on a media player (if off) and switch it to a specified source.
I have the following in a yaml file in custom_sentences/en:
CustomMediaSetSource:
- sentences:
- Watch [the] {mediaSource}
- Set [Source] [to] {mediaSource}
- Play [the] {mediaSource}
- Change (TV|Stereo) [to] {mediaSource}
lists:
mediaSource:
values:
- "PS5"
- in: "Playstation"
out: "PS5"
- in: "Playstation 5"
out: "PS5"
- "Switch"
- in: "Switch 2"
out: "Switch"
- "AppleTV"
- "XBox"
(so the utterance “Watch the AppleTV” should turn on the media player and switch the source to “AppleTV”)
I have an intent:
- action: script.tv_turn_on_and_set_source
data_template:
source: "{{ mediaSource }}"
speech:
text: "{{ action_response | pprint }}"
and the script is:
sequence:
- variables:
changed_on: false
source_changed: false
response:
text: ""
- if:
- condition: not
conditions:
- condition: state
entity_id: input_boolean.tv_stereo_power
state: "on"
then:
- variables:
changed_on: true
response[text]: Power On
- action: input_boolean.turn_on
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- if:
- condition: not
conditions:
- condition: template
value_template: >-
{{ state_attr('media_player.marantz_cinema_60', 'source') ==
source }}
then:
- variables:
source_changed: true
response[text]: >
{{ response[text] }} {%- if (response[text] | length) > 0 %} and
changed {%- else -%}
change
{%- endif %} source to {{ source }}
- action: media_player.select_source
metadata: {}
source: "{{ source }}"
entity_id: media_player.marantz_cinema_60
- if:
value_template: "{{(response[text] | length) == 0}}"
then:
- variables:
response[text]: The TV is already on and set to {{ source }}
- stop: Complete
response_variable: response
alias: TV - Turn on and set source
description: ""
variables:
source:
name: Source to change to
Looking at traces and testing - the script fires fine, but I want to return text from it for the assistant to actually “say” (so it can tell me what happened)
Using the set_conversation_response: command inside the script itself generates the following error:
TypeError: can't access property "speech", a.data.intent_output.response.speech.plain is undefined
isToolResult (src/components/ha-assist-chat.ts:547:12)
event.type.startsWith (src/components/ha-assist-chat.ts:433:33)
So the current version sets response.text to what it should read out, and I thought that via script response variables I could pass this through to the intent_script call via response_variable but i can’t seem to be able to set anything.
Does anyone know if this approach will work? Am I just stuck doing this as an automation? (which has the hassle of needing to use wildcard matches which seem very greedy)
