Many users are accepted that Xiaomi Mi Flora sensors are not precise, especially humidity. I put two sensors in same conditions and humidity reading differs more than 10% (temperature, light… are more equal).
I propose to add in Miflora integration correction factors for every sensor so we can calibrate readings with etalon.
You could just create a template sensor which offsets the original sensor and then use the template sensor in your dashboard/automations etc.
I know about templates, but as humidity inaccuracy is rule, not exception on those devises, native correction would be convenient way for many users.
Sure, good luck then with your feature request. I honestly don’t think a dev will pick it up when there’s an easy workaround.
Btw, vote for your own request
Bonjour,
Je suis un peu novice dans ce domaine. J’aimerais savoir comment corriger les écarts d’humidité sur mes capteurs ?
Merci d’avance
