I’m having issues with the Alexa Applestrudel nodes in Node Red and I’m just hoping someone can verify I’m not doing something to cause the issue when I try and configure my Alexa account.
I can successfully configure my account and send TTS requests to my Alexa devices, but after a while the nodes tell me I need to go to my ip HA ip address on port 3456 and I have to re-authenticate.
I followed the set up instructions and I’m using the following settings:
Auth: Proxy
IP: my ip
Port: 3456
Path: * See note below
Refresh: 3 days
Auto-init: On
Events: on
I then have the various service host etc. information set for my region.
With regards the path, I am not too sure what I need to put here? Can I just put something like /auth or do I need to specify an existing folder in my file structure? If the folder needs to exist where should this be located? I can SSH in to my HA server but I wouldn’t know the location I need.
I feel like this should be easy and I’m doing something wrong, so any assistance would be really appreciated.
If any further information is required I will try to provide it if requested.
Many thanks in advance
