I made the cardinal sin of not checking my config file before doing a reboot and now my Home Assistant won’t start.
I’ve corrected the mistake that was in automations.yaml.
I’ve got access to the web interface over https (just says “Connecting” and then times out), I’ve got access to the configuration files (using the Hassio web based plug in), but I’ve not got access to the command line (I’m away for Christmas).
Is there anything I can do to force my home assistant to restart? Perhaps a feature request to try and restart automatically after 10 minutes if the configuration files are in error should be in order?
If you can’t get access to the terminal to force a restart of the service, or perform a reboot, then you’ll need to find a way of power cycling the device.
