Hi my disk filled up to 1005 while I was busy with life. this seems to have corrupted my Energy data.
I have obviously cleared some space and restarted docker container but i still get the following error.
Is there someway I can repair the db without losing all the data ?
File "/usr/local/lib/python3.12/site-packages/homeassistant/components/recorder/util.py", line 228, in execute_stmt_lambda_element
executed = session.execute(stmt)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2308, in execute
return self._execute_internal(
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2180, in _execute_internal
conn = self._connection_for_bind(bind)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2047, in _connection_for_bind
return trans._connection_for_bind(engine, execution_options)
File "<string>", line 2, in _connection_for_bind
error from daemon in stream: Error grabbing logs: invalid character 'l' after object key:value pair
