I’ve just barely started bringing in both my electric and gas usage with an SDR dongle using the awesome AMR2MQTT integration The values come in well. I also compute the current cost in node red and send it as a MQTT value as our utility prices are a tier based method where the cost changes once your usage passes a certain threshold as well as seasonally. The cost is working for electricity, but despite using an identical methodology is not working for gas. Where should I start troubleshooting? Are there any hooks behind the scene I can use to trace the problem? I am seeing a message in the logs:
Found unexpected unit ft³ for sensor.gas_meter_daily
This message just recently appeared. Is only m^3 allowed?
