Somewhat related topic that I also posted in @flynmoose newbie guide. I’ve got another device with a TYWE2S module I’m trying to flash; however, its onboard components are going to make heat flowing the solder points very difficult to do without damaging them, at least without professional equipment. So my question which I don’t think has been asked yet is has anyone tried just removing the TYWE2S module cover/lid? Here’s a generic pic I found on the web of what I’m talking about:
It looks to be just held on with some sporadic solder around the edges. If that can be removed to expose the ESP8285 chip, then we could access the GPIO directly on the chip (pin 15 IIRC). Sure that isn’t a simple task any amateur with a soldering iron can do, but I’m confident anyone with at least some moderate experience, a steady hand, some fine wire, and a magnifying glass or scope could easily do… at least something sufficient enough to temporarily ground out GPIO0 to enter flash mode.
Again, it might be nearly as difficult as just removing whole module in the case of the Feit Dimmer; however, in other situations (e.g. my candelabra bulb I’m working on) it might be more doable. I plan to give it a whack next week if no one has tried this.
Update: the covers on these module pry off fairly easily… I gently pried mine off with a scribe. I’ll try flashing it later tonight or tomorrow, and report back how it goes.
