Hello
I’v added the Tuya integration and it is possible to add an account for the ‘Smart Life’ app when selecting:
platform: smart_life
Now I’m using the ‘LSC Smart Connect’ app for my Tuya devices bought in Belgium (but I think the same goes for the Netherlands en Germany)
Could this be added to the Tuya integration?
With the Tuya integration is it not possible to add the Smart Connect app.
I have tried my credentials but the devices don’t show up in Home assistant.
I’m not planning to flash my devices, but just use ‘LSC Smart Connect’ side by side with Home Assistant to control these smart devices.
I know it is possible like you suggest but that Smart Life app is not so responsive.
For example, I have to click several times on a light to turn it on. Tapping the 3 dots to modify a smart tap-to-run need 4 or more taps
Not sure if other people experience the same problem, but this holding me from moving all my 40 lights and 5 smartplugs and sensors from the LSC Smart Connect app to the Smart Life app
I only have 2 ‘smart plaffonieres’, which can’t be flashed with tasmota since they don’t have an esp. And I never use the app, just the HA integration.
Hello, at home I have LSC door opening sensors, they are installed in smart life but do not go up in HA, I would like to be able to integrate them in order to know the status in the dashboard. thank you
