### The problem
I encountered issues with multiple integrations (GoodWe, Tuya, …Ariston, HACS). Any integration attempting to use UDP or network discovery fails with PermissionError or Network Unreachable. This is a system-wide networking issue affecting the Docker host mode over Wi-Fi.
### What version of Home Assistant Core has the issue?
core-2026.2.1
### What was the last working version of Home Assistant Core?
core-2026.2.1
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
GoodWe, Ariston, HACS, Tuya
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
```yaml
### Anything in the logs that might be useful for us?
```txt
Source: config_entries.py:749
First occurred: 9:58:37 PM (1 occurrence)
Last logged: 9:58:37 PM
Error setting up entry GoodWe for goodweTraceback (most recent call last):
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 749, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/goodwe/__init__.py", line 21, in async_setup_entry
inverter = await connect(
...<3 lines>...
File "/usr/local/lib/python3.13/site-packages/goodwe/__init__.py", line 56, in connect
await inv.read_device_info()
File "/usr/local/lib/python3.13/site-packages/goodwe/et.py", line 461, in read_device_info
response = await self._read_from_socket(self._READ_DEVICE_VERSION_INFO)
File "/usr/local/lib/python3.13/site-packages/goodwe/inverter.py", line 132, in _read_from_socket
result = await command.execute(self.host, self.timeout, self.retries)
File "/usr/local/lib/python3.13/site-packages/goodwe/protocol.py", line 149, in execute
transport, _ = await loop.create_datagram_endpoint(
...<2 lines>...
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1461, in create_datagram_endpoint
raise exceptions[0]
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1448, in create_datagram_endpoint
await self.sock_connect(sock, remote_address)
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
return await fut
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 649, in _sock_connect
sock.connect(address)
PermissionError: [Errno 13] Permission denied
Logger: custom_components.ariston
Source: custom_components/ariston/__init__.py:88
integration: Ariston (documentation, issues)
First occurred: 9:58:34 PM (2 occurrences)
Last logged: 9:58:55 PM
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1248, in _wrap_create_connection
sock = await aiohappyeyeballs.start_connection(
...<6 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 122, in start_connection
raise first_exception
File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 73, in start_connection
sock = await _connect_sock(
...<6 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 208, in _connect_sock
await loop.sock_connect(sock, address)
return await fut
OSError: [Errno 101] Network unreachable
File "/config/custom_components/ariston/__init__.py", line 88, in async_setup_entry
device = await ariston.async_hello(
...<2 lines>...
File "/usr/local/lib/python3.13/site-packages/ariston/__init__.py", line 78, in async_hello
await self.async_discover()
File "/usr/local/lib/python3.13/site-packages/ariston/__init__.py", line 65, in async_discover
cloud_devices = await _async_discover(self.api)
File "/usr/local/lib/python3.13/site-packages/ariston/__init__.py", line 187, in _async_discover
] = await asyncio.gather(
api.async_get_detailed_devices(), api.async_get_detailed_velis_devices()
File "/usr/local/lib/python3.13/site-packages/ariston/ariston_api.py", line 551, in async_get_detailed_velis_devices
detailed_velis_devices = await self._async_get(
f"{self.__api_url}{ARISTON_VELIS}/{ARISTON_PLANTS}"
File "/usr/local/lib/python3.13/site-packages/ariston/ariston_api.py", line 992, in _async_get
return await self.__async_request("GET", path, params, None)
File "/usr/local/lib/python3.13/site-packages/ariston/ariston_api.py", line 948, in __async_request
response = await session.request(
method, path, params=params, json=body, headers=headers
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 770, in _request
resp = await handler(req)
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 725, in _connect_and_send_request
conn = await self._connector.connect(
req, traces=traces, timeout=real_timeout
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 622, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1189, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1561, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1530, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
...<7 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1271, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host www.ariston-net.remotethermo.com:443 ssl:default [Network unreachable]
### Additional information
This is a host-level kernel regression. If you encounter this, downgrading the kernel to 6.8.0-94-generic restores full functionality. This seems to be related to how the new kernel handles unprivileged UDP sockets over Wi-Fi.
