i have the following configuration:
livingroom_g:
friendly_name: Livingroom
level_template: >-
{% if states.sensor.gekko_light is defined and states.sensor.gekko_light.attributes['item0'] is defined %}
{{ state_attr('sensor.gekko_light','item0').split(';')[1]|int }}
{% else %}
{{ state_attr('light.livingroom_g','brightness') }}
{% endif %}
value_template: >-
{% if states.sensor.gekko_light.attributes['item0']['sumstate']['value'].split(';')[0]|float == 1 %}
on
{% else %}
off
{% endif %}
{% else %}
{{ states('light.livingroom_g') }}
{% endif %}
turn_on:
- service: rest_command.rest_gekko_light
status: 1
item: item0
- service: homeassistant.update_entity
entity_id: sensor.gekko_light
turn_off:
status: 0
item: item0
But in HomeAssistant no Brightness attribute appears. Even when i put a number to level_template e.g. 128. There is no attribute.
What am i doing wrong ?
The value_template is working fine and the value which i am splitting is something like: “0;100.00;16764280;0;”
Any suggestions ?
