Could not login to Xiaomi Miio Cloud, check the credentials
After I got the IP and Token of the device that I need, i used back the Xiaomi Home app and select ‘Configure manually (not recommended)’ and click submit. No username and password is required. On the next screen, key in your device IP and Token and they will be re-authenticated. I believe this only works for devices that are run locally.
