I’ve got Dell Wyse D90D7 with two disks: first is 16GB SSD connected directly to motherboard’s SATA socket and second is 1TB HDD connected to additional SATA port. I’ve installed generic x86_64 image on 16GB disk - this runs perfectly. Now I want to “move datadisk” to 1TB HDD (according to this manual: https://peyanski.com/home-assistant-external-data-disk/) but UI and also HaOS CLI tells me that there is no datadisk available (ha os datadisk list
shows empty list). Strange because both of them are visible on Hardware tab, 16GB SSD as /dev/sda and 1TB HDD as /dev/sdb. What’s the problem? Is there any solution?
