I’ve the last installation of hass.io (0.63.2) with ssh and duckdns addons on raspberry pi3.
Recently, I noted a connection problem with external resource, I couldn’t resolve external host:
core-ssh:~# curl https://home-assistant.io
curl: (6) Could not resolve host: home-assistant.io
And in the logs panel of the duckdns addon screen:
starting version 3.2.2
# INFO: Using main config file /data/workdir/config
ERROR: Problem connecting to server (get for https://acme-v01.api.letsencrypt.org/directory; curl returned with 6)
Did you setup the static ip editing the resin-sample file? Did you set the DNS server there too?
BTW, if you can it is easier to use DHCP reservations to give a predefined address to the RPi.
I setup de static ip from the resin-sample file, directly on the sd card. In the past, everything was ok.
Now, it’s strange cause I can do the update of the hass.io and the addons (from the frontend interface, hass.io menu) but I can’t reach any external ip from de ssh client and my duckdns doesn’t update the IP.
I will make the configuration change that you notice me. I’ll come back with more feedback.
