Hi All,
I see many times this error:
Could not update status for Nanoleaf (192.168.100.2 is not available)
I did power off the Nanoleaf and restart it again, didn’t work.
When I see this error the Nanoleaf still react on actions using HA
Yesterday I had this error:
2020-06-13 22:07:21 ERROR (MainThread) [homeassistant.components.automation] Scene - Evening: Error executing script. Unexpected error for call_service at pos 5: 192.168.100.2 is not available
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 426, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 421, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.7/http/client.py", line 1344, in getresponse
response.begin()
File "/usr/local/lib/python3.7/http/client.py", line 306, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.7/http/client.py", line 267, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.7/socket.py", line 589, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 403, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 428, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
self, url, "Read timed out. (read timeout=%s)" % timeout_value
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.100.2', port=16021): Read timed out. (read timeout=2)
File "/usr/local/lib/python3.7/site-packages/pynanoleaf/pynanoleaf.py", line 188, in _request
response = self._session.send(req.prepare(), timeout=self.timeout)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.100.2', port=16021): Read timed out. (read timeout=2)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 153, in _async_step
self, f"_async_{cv.determine_script_action(self._action)}_step"
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 656, in _async_call_service_step
*self._prep_call_service_step(), blocking=True, context=self._context
File "/usr/src/homeassistant/homeassistant/core.py", line 1259, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1294, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
self._platforms.values(), func, call, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 454, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 597, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 485, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 242, in async_handle_light_on_service
await light.async_turn_on(**params)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 622, in async_turn_on
await self.hass.async_add_executor_job(ft.partial(self.turn_on, **kwargs))
File "/usr/src/homeassistant/homeassistant/components/nanoleaf/light.py", line 210, in turn_on
self._light.brightness = int(brightness / 2.55)
File "/usr/local/lib/python3.7/site-packages/pynanoleaf/pynanoleaf.py", line 109, in brightness
self._put("state", {"brightness": {"value": value}})
File "/usr/local/lib/python3.7/site-packages/pynanoleaf/pynanoleaf.py", line 219, in _put
self._request(path, 'PUT', data)
File "/usr/local/lib/python3.7/site-packages/pynanoleaf/pynanoleaf.py", line 194, in _request
raise Unavailable("{} is not available".format(self.host)) from e
pynanoleaf.pynanoleaf.Unavailable: 192.168.100.2 is not available
2020-06-14 06:26:01 ERROR (SyncWorker_12) [homeassistant.components.nanoleaf.light] Could not update status for Nanoleaf (192.168.100.2 is not available)
What can I do to solve this?
