I’m getting this error on and off with the Bluetooth tracker:
Logger: homeassistant.components.bluetooth_tracker.device_tracker
Source: components/bluetooth_tracker/device_tracker.py:73
Integration: bluetooth_tracker (documentation, issues)
First occurred: 10:42:08 AM (1 occurrences)
Last logged: 10:42:08 AM
Couldn't discover bluetooth devices: error communicating with local bluetooth adapter
I got a few devices tracked and it used to work with a Pi3B, now I moved to a mini computer and bought an external BT dongle, running the latest version of HAOS (7.4). Could it be that the dongle isn’t fully compatible?
All the posts I see about this error are from 2020. My dongle is meant to be BT 5.1.
Anything else I could have a look at? I still have time to return the dongle if that’s the issue.
I forgot to answer to my post but I found out that connecting the dongle further from other BT sources (like laptop or mouse) improved a bit the quality.
I bought another one and it was even worse, so I ended up returning the new one
So just installed it and I noticed after a while it was consuming a lot of CPU… As soon as I turn it off, it went from 80% more to like 10% CPU usage… Could it be because I have other add-ons using the BT interface?
Is this project maintained? I attemted to install and setup the plugin made by Limych and I cannot connect to the local MQTT server. I attemted to use the LAN IP and the 127.0.0.1 using a user/pw that works great with a Room-Assistance monitor.
