Couldn't find ID 'font' error when using SSD1306 OLED Display
Hi, Can anyone spot what could be wrong here? I keep getting errors like this…
Failed config
display.ssd1306_i2c:
  platform: ssd1306_i2c
  model: SSD1306_128X64
  address: 0x3C
  Couldn't find ID 'font'. Please check you have defined an ID with that name in your configuration. These IDs look similar: "my_font".
  lambda: !lambda |-
    it.print(0, 0, id(font), "Hello World!");
  brightness: 1.0
  update_interval: 1s
Here’s my code so far…
esphome:
  platform: ESP32
  board: esp32-poe-iso
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  power_pin: GPIO12
  manual_ip:
    static_ip: 10.0.0.246
    gateway: 10.0.0.139
    subnet: 255.0.0.0
i2c:
  sda: 13
  scl: 16
  scan: True
font:
  - file: "Comic Sans MS.ttf"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    #reset_pin: D0
    address: 0x3C
    lambda: |-
  - platform: bme280
    temperature:
      name: "BME280 Temperature"
      oversampling: 16x
    pressure:
      name: "BME280 Pressure"
    humidity:
      name: "BME280 Humidity"
    address: 0x76
    update_interval: 10s
web_server:
  port: 80
logger:
  level: VERBOSE
  #baud_rate: 19200
It’s doing my head in :slight_smile:
I found the problem!
display:
    #reset_pin: D0
    address: 0x3C
    lambda: |-
      it.print(0, 0, id(my_font), "Hello World!");
Just need the “my_” added in front of font (see the bottom line).
hey … can you explain from where you are getting the font pls?
G’day mouthpiece. I can’t remember exactly where i got it from as it’s been awhile and I have trouble remembering what I did yesterday, but I would’ve downloaded it off the internet somewhere. This site possibly could’ve been it https://www.wfonts.com/font/comic-sans-ms You can always change it to something else too.
thanks for getting back to me :slight_smile: I managed, just downloaded the fonts after a random google search and all worked fine.
Having the same issue. I downloaded the font (on my laptop), but how do I get it into HA / ESPHome?
You move the font to your esphome config folder. It should say where your file should be, if you hover over the error in yaml.
2.5 years later I’m replying because I just had this problem.
I used the Samba Share add-on to allow me to mount HA’s config directory as a Windows network share.
  1. Enable the official Samba Share add-on (Settings > Add-ons > Samba Share)
  2. Configure the user/password (Samba Share page > Configuration Tab)
  3. Enable the add-on (General Tab > Start button in the main area of the page)
  4. Map a network drive in Windows Explorer
    • Use \192.168.1.x\config as the IP and share name for the HA config directory
    • Enable “Use Different Credentials” and enter the configured values from Step 2 into the Windows network drive UI
