Hi, I am new to Home Assistant. Inspired by some youtube videos and forum like this. I have created my home automation to switch ON/OFF lights in my home. The hardware is connected to my MQTT server.
The mqtt entities are added in HA in the configurations.yaml file like below
mqtt:
switch:
- name: “Valve 1”
unique_id: “Valve 1”
state_topic: “xxxxx/trigger”
command_topic: “xxxxxxxx/trigger”
payload_on: 1
payload_off: 0
optimistic: false
retain: true
- name: "Groud Floor Light"
unique_id: "SW1"
state_topic: "xxxxx/S1"
command_topic: "xxxxxxx/S1"
payload_on: "ON"
payload_off: "OFF"
optimistic: false
retain: true
and so on.
and it works fine.
Now I wanted to put a card showing number of Active / ON lights in my home. (mqtt switch)
got some info like this
{{ states.switch|selectattr(‘state’,‘equalto’,‘on’)|list|length }}
but which file this has to be added.
Anyone can help me?
Troon
(Troon)
July 15, 2024, 6:39am
2
sksanthosh:
It doesn’t have to be added to a file at all. Create a template sensor helper:
Settings
Devices & Services
Helpers
Create
Template > template a sensor (not binary sensor)
Paste your template into the state template box. Note that because you didn’t correctly format your code above, the quotes are wrong, so here’s a fixed version:
{{ states.switch
|selectattr('state','eq','on')|list|length }}
Note that this counts all switches, not just your MQTT ones.
got it and its easy too. thank you.
also how to filter the switch within an area. that is to count only switch in home area like that
Troon
(Troon)
July 15, 2024, 10:47am
4
Line breaks only for readability, can be all on one line:
{{ area_entities('AREA_NAME')
|select('match','switch.')
|select('is_state','on')
|list|count }}
area_entities() (doc ) returns a list of entity IDs, which we then restrict with match (doc ) to those starting with “switch.”, then run the is_state test (doc ).
clear. and got the result as expected.
Also is there any option to change the light colour when there is no lights active.
type: horizontal-stack
cards:
type: custom:mushroom-entity-card
entity: binary_sensor.sw_light_status
icon: mdi:connection
icon_color: cyan
tap_action:
action: more-info
layout: horizontal
hold_action:
action: more-info
fill_container: true
entity: sensor.active_lights_2
layout: horizontal
icon: mdi:ceiling-light-multiple
icon_color: accent
tap_action:
action: more-info
name: 'Active Lights ’
layout_options:
grid_columns: 4
grid_rows: 1
