Hi everybody,
I have a nodemcu v2
with this configuration below.
Is it possible to achieve the following without writing a custom_component? (will explain what this is for underneath the yaml code)
- when
binary_sensor.counter
(from code below) switches fromoff
toon
- set a temporary number to
1
- see, how many more times this sensor switches from
off
toon
within 500ms - for each time it does (within this time frame), increase the temporary value by
1
- after this 500ms time frame
- return this value (it will be between 1 and 5)
- reset this value to 0
- depending on what this temporary number has counted to before returning to
0
- if 1 > set
input_number.current_value
to2
- if 2 > set
to1
- if 3 > set
to0.5
- if 4 > set
to0.2
- if 5 > set
to0.1
- whenever
changes
- add its value (2 / 1 / 0.5 / 0.2 or 0.1) to
input_number.total_value
- (I guess I can do this through Home Assistant)
- manually reset
via button_press…
I know there is delay
and interval
, but I just cannot wrap my head around complex ESPHome code.
Thank you in advance for your help.
esphome:
friendly_name: 00/Test/Coinslot
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "asdasdsad"
ota:
password: "asdasdsa"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Testcoinslot Fallback Hotspot"
password: "asdasdasd"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: D4
inverted: True
Why?
I have a CH-926
coin slot, which will send a different amount of pulses depending on what coin has been inserted. It will send 1 pulse for a 2 EUR coin, 2 for a 1 EUR coin, etc. to 5 pulses for 10 Cents.
These pulses are just on/off switches within a very short time frame. I have tried using pulse counter etc. for this, but it didn’t seem to work.
Then I found an arduino code example, but it seems impossible to integrate it into ESPHome as a custom_component (because I just don’t know enough about it).
The workflow I listed above is an analogue way to achieve what the arduino code would do. Always check how many times the signal has been turned from low to high within a set period of time (they use 30ms, I thought I’d use 50ms instead).
EDIT:
I tried the code below as well.
- platform: pulse_meter
pin: D6
timeout: 1s
internal_filter: 20ms
This, however, will not produce the desired output. When I expect one single pulse, I get 500.000 pulses/min
. This can be filtered via multiply: 0.06
, but then I get values between 9.nnn
to 27.nnn
I need to start measuring pulses when the first pulse occurs, then count them, then stop. No average per minute. If I understand correctly, the device should send 1,2,3,4, or 5 pulses. Not 9 dot something, not 18 dot something. 1 to 5. These should somehow be registered / identified. But I am just getting lost more and more here.
