Count each time the temperature rises above 30 degrees
Hello
Is there anyone who can help me?
Calculate the number of times the temperature rises above 30 degrees in a
counter
Device name
sensor.temp_4
feed a counter
can i use Statistics Sensor ?
# enable the recorder integration (optional)
recorder:
# Example configuration.yaml entry
  - platform: statistics
    entity_id: sensor.temp_4
best regards
or…how about using a counter…?
Thanks @finity
I think I create one Template Binary Sensor
binary_sensor:
    sensors:
      furnace_on:
        friendly_name: "Temp above 30"
        device_class: heat
        value_template: "{{ states('sensor.temp4')|float > 30 }}"
and a counter
counter:
  my_custom_counter:
    initial: 30
    step: 1
    icon: mdi:alert
I can create several ?
counter:
  my_custom_counter:
    initial: 30
    step: 1
    icon: mdi:alert
  error_counter:
    icon: mdi:alert
Finally an automation that counts the number of times the sensor changes the value to on
Is there anyone who can help a novice
Best regards
