Hi all, i’m tryng to create a sensor that count the hour of sun during the day. I used the history_stats but i had to add in start and end the variable of the sunrise and the sunset because the weather component keey the sunny state even if is night.
Can this work? :
- platform: history_stats
name: Ore di Sole Oggi
entity_id: weather.milano
state: 'sunny'
type: time
start: "{{ state_attr('sun.sun', 'next_rising') }}"
end: "{{ state_attr('sun.sun', 'next_setting') }}"
sunlight:
value_template: >
{% set nr = as_timestamp(state_attr('sun.sun','next_rising')) %}
{% set ns = as_timestamp(state_attr('sun.sun','next_setting')) %}
{% if nr > ns %}
{% set nr = nr - 60*60*24 %}
{% endif %}
{{ (ns - nr)|timestamp_custom('%H:%M',false) }}
just realized that this can not work because the “next_rising” or “Next_setting” change immediatly to thge next day when the event occurs…
need a way to take this date and do a "-1) on the number of the day… but this can be a problem if the number of the day is 1…
#SENSOR GO TRUE IF WEATHER IS SUNNY AND SUN IS ABOVE HORIZON
sensors:
sole_e_alba:
friendly_name: "Sole e alba"
value_template: >-
{{is_state('weather.milano', 'sunny')
and is_state('sun.sun', 'above_horizon')}}
#SENSOR COUNT HOUR OF SUN UP AND SUNNY OF THE PREVIOUS SENSOR
entity_id: sensor.sole_e_alba
state: 'True'
type: time
start: '{{ now().replace(hour=0, minute=1, second=0) }}'
end: '{{ now().replace(hour=23, minute=59, second=0) }}'
