This is a simple script that will count the number of times that it is invoked.
counter = hass.states.get('sensor.my_counter')
if counter is None:
value = 0
else:
value = int(counter.state)
hass.states.set('sensor.my_counter', value + 1)
if counter is None:
value = 0
else:
Could you also add the counter as an attribute?
this_script = hass.states.get('python_script.this_script')
attributes = this_script.attributes.copy()
try:
attributes['counter'] += 1
except KeyError:
attributes['counter'] = 1
this_script.state, attributes=attributes)
Yep, you could do that too. Note that state attributes are immutable. Instead, you should create a copy and update it.
hass.states.set('sensor.my_counter', this_script.state, {
'counter': value
So, would my edited code above be correct?
Try it out
Ok, I have a script that works now. How do I make it run on a regular basis?
You will have to create an automation to trigger that. Also, please post the updated working script
Here is a sample python script that hides all the devices that have state “Online”, leaving just the “Offline” ones in the UI… I got so many devices, and I only ant to see the Offline devices in the group/card. This script takes care of that.
count = 0
for entity_id in hass.states.entity_ids('sensor'):
entity_state_object = hass.states.get(entity_id)
if entity_state_object.state == 'Online':
attributes = entity_state_object.attributes.copy()
attributes['hidden'] = True
hass.states.set(entity_id, entity_state_object.state, attributes=attributes)
count = count + 1
logger.info("{} entities are hidden.".format(count))
I think I’m doing the same thing here but, the attribute doesn’t appear to be updating:
entity_id = data.get('entity_id')
states = hass.states.get(entity_id)
atts = states.attributes.copy()
if states.state == "off":
atts['blackout'] = False
hass.states.set(entity_id, states.state, atts)
else:
if states.attributes.get('blackout') == False:
atts['blackout'] = True
After the script has run while the entity is off
I do not see the blackout
attribute added to the entity. Where did I go wrong?
I didn’t think you could control the visiblity of entities / devices, only groups.
https://home-assistant.io/docs/configuration/group_visibility/
