I copied a bit of code from here awhile back that worked perfectly until just recently (2024.9.x upgrades). What it did was count all of the lights/sockets that were on in each room. However now, each room reports zero even thought the entity is on.
- name: "Number of Sockets On"
unique_id: c838cee8-1919-4000-8fc0-d6587433e6fc
attributes:
navigation: sockets
label: >
{%- if this.state | int(0) > 0 -%}
{{ this.state }} On
{%- else -%}
All Off
{%- endif -%}
entities: >
{%- from 'tools.jinja' import list_entities -%}
{{ list_entities(states.switch,device_class='outlet',state='on') }}
count: >
{%- from 'tools.jinja' import count_entities -%}
{%- set ns = namespace(entities=[], tmp=[]) -%}
{%- for s in states.switch | map(attribute='entity_id') | map('area_name') | unique | reject('none') | list -%}
{%- set ns.tmp = ns.tmp + [ (s, count_entities(states.switch,device_class='outlet',state='on',area=s) | from_json )] -%}
{%- endfor -%}
{%- for key, value in ns.tmp -%}
{%- if key == 'House' -%}
{%- set value = count_entities(states.switch,device_class='outlet',state='on') | from_json -%}
{%- endif -%}
{%- set ns.entities = ns.entities + [ (key, value)] -%}
{%- endfor -%}
{{ dict.from_keys(ns.entities) }}
state: "{{ this.attributes.entities | count }}"
icon: mdi:power-socket-uk
If I remove the device_class=outlet it provides the wrong count as it adds in items that are switches, but not outlets or lights.
