I’m trying to help an automation get configured using a counter.
Counter runs every time a SumpPump is run. I duplicated the counter and called it hourly and reset it every hour.
My goal is to have a template sensor read the value so it can be graphed and some history on the hourly value. I cannot seem to get value to copy over to a last_hour counter. Should I be using an input number instead to store the hourly value before reset and then make a template sensor off its value?
Example automation that is not working.
- alias: Sump Pump Pit 1 Activations Counter - Hourly
- platform: time_pattern
minutes: 0
- service: counter.configure
entity_id: counter.sump_pump1_activations_counter_last_hour
value: {{ states.counter.sump_pump1_activations_counter_current_hour.state | int }}
- service: counter.reset
entity_id: counter.sump_pump1_activations_counter_current_hour
