Counter warning/error - issue
I’m trying to use the counters to show the number of errors/warnings, but it’s not reporting anything?
I’m using the latest hass release 0.84.3 - Is anyone using these counters for error counting ?
- alias: 'Counter error'
  initial_state: True
  - platform: event
    event_type: system_log_event
    event_data:
      level: ERROR
    - service: counter.increment
      entity_id: counter.error
- alias: 'Counter warning'
    platform: event
    event_data:
      level: WARNING
    entity_id: counter.warning
anyone…?
Are you sure the shape of your event trigger is correct? What does the event data look like in the homeassistant.log file?
I have this in the log
2018-12-19 20:19:46 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘event’
2018-12-19 20:19:59 WARNING (Thread-8) [custom_components.sensor.plex_recently_added] Host 213.49.94.127 is not available
2018-12-19 20:20:03 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘event’
2018-12-19 20:20:04 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘event’
2018-12-19 20:20:05 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘event’
well that’s an error, doesn’t show the event data. That could be the cause of your problem. If you change the logging level to INFO you should be able to see the actual event data.
petro
still nothing, as per your advice
logger:
  default: INFO
2018-12-21 22:25:53 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.illuminance which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-21 22:25:53 INFO (MainThread) [homeassistant.loader] Loaded sensor.waze_travel_time from homeassistant.components.sensor.waze_travel_time
2018-12-21 22:25:53 INFO (MainThread) [homeassistant.loader] Loaded sensor.Places from custom_components.sensor.Places
2018-12-21 22:25:53 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.Places which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
I think you may need to add debugging.
Try adding this to logger:
# Example configuration.yaml entry
logger:
  default: info
  logs:
    homeassistant.components.logger: debug
yes, i do, and I think it is identical…
  - alias: Count warnings
    id: 'Count warnings'
#    initial_state: 'on'
      platform: event
      event_data:
        level: WARNING
      entity_id: counter.warning_counter
  - alias: Count errors
      platform: event
      event_data:
        level: ERROR
      entity_id: counter.error_counter
even had to reset the restore state to not restore errors counted on restart:
counter:
  warning_counter:
    icon: mdi:alert
    restore: False
  error_counter:
    icon: mdi:alert-circle
    restore: False
# Scripts
script:
  reset_error_counter:
    alias: 'Reset Error counter'
    sequence:
      service: counter.reset
  reset_warning_counter:
    alias: 'Reset Warning counter'
    sequence:
@elRadix sorry to warm this old thread up, but I just stumbled over the same problem.
The fix, in my case, was to add:
system_log:
  fire_event: true
to the configuration.yaml… and it started working :wink:
can you share your full config please :sweat_smile:
This is how it’s configured now:
system_log:
  fire_event: true
counter:
  homeassistant_errors:
    icon: mdi:alert-octagram
    restore: false
  homeassistant_warnings:
    icon: mdi:alert
    restore: false
automation:
  - alias: Count Home Assistant errors
      platform: event
      event_data:
        level: ERROR
      entity_id: counter.homeassistant_errors
  - alias: Count Home Assistant warnings
      platform: event
      event_data:
        level: WARNING
      entity_id: counter.homeassistant_warnings
script:
  homeassistant_reset_error_counter:
    alias: 'Fehler zurück setzen'
    sequence:
  homeassistant_reset_warning_counter:
    alias: 'Warnungen zurück setzen'
    sequence:
Is it possible to track errors/warnings during HA startup ?
2022.2.9 - my counters become incrementing some time after HA started.
