yfands
(Frank)
March 29, 2021, 11:09pm
1
Hey guys,
Iam trying to create a status page where I can see with one quick glance the status of my devices.
iam struggling with the count of devices (per device_class, motion, temperature, window, door) which have a low battery. I dont have to know which devices have a low battery level, just how many.
I came across several solutions for instance:
a blueprint https://community.home-assistant.io/t/low-battery-level-detection-notification-for-all-battery-sensors/258664
or:
https://community.home-assistant.io/t/howto-create-battery-alert-without-creating-a-template-for-every-device/30576
but I was more looking for a one-liner something like:
{{ states | selectattr('attributes.device_class', 'eq', 'motion') | selectattr('attributes.device_class', 'eq', 'battery') | selectattr('state', '<=','20') | list | count}}
I tried several several combinations from several one-liner examples, But I lack the skills to figure this out, if even possible.
Somebody?
Thanks in advance
Frank
I am using this sensor provided by a user to count any battery devices below 10%. You can dissect what you need from it.
sensors:
devices_with_low_battery:
friendly_name: 'Devices with low battery'
unit_of_measurement: devices
value_template: >-
{% set ignore_entities = ['sensor.id_battery_level', 'sensor.hallway_door_battery', 'sensor.cr_curtains_battery', 'sensor.lr_curtains_battery'] %}
{{ states.sensor
| rejectattr('entity_id', 'in', ignore_entities)
| map(attribute='state')
| reject('in', ['unknown', 'unavailable'])
| map('int', -1) | select('le', 10)
|select('ge', 0)
| list | count
icon_template: >-
{% if is_state('sensor.devices_with_low_battery', '0') %}
mdi:check-circle
{% else %}
mdi:battery-alert
{% endif %}
Kev1
(Kevin Burr)
March 30, 2021, 5:10am
3
I use Auto Entities with this code.
card:
type: entities
state_color: true
title: Batteries
filter:
include:
- attributes:
device_class: battery
state: < 30
exclude:
- entity_id: sensor.mancave_door_blind_power
sort:
method: state
reverse: true
show_empty: true
yfands
(Frank)
March 30, 2021, 7:58pm
4
Thank you both, will give it a try…
hfink
(Holger)
August 26, 2022, 5:01pm
5
I am not sure what I am doing wrong, but I keep getting a message when I test the template that the attribute device class is not available for the domain “sensor”
Any thoughts what I am doing wrong here!?
hfink
(Holger)
August 26, 2022, 5:05pm
6
UndefinedError: ‘homeassistant.util.read_only_dict.ReadOnlyDict object’ has no attribute ‘device_class’
This is the exact error I am getting using this in the template editor:
{{ states.sensor
|select('ge', 0)
| list | count
123
(Taras)
August 26, 2022, 5:39pm
7
Add the first selectattr shown below.
{{ states.sensor
| selectattr('attributes.device_class', 'defined')
|select('ge', 0)
| list | count
hfink
(Holger)
August 26, 2022, 5:50pm
8
nice… that’s solved it
Thank you very much for your help
Hi Is there a way to exclude all sensor from a particular integration, to be precise I want the result of number of low battery but I don’t want any sensor from all mobile APPs, I don’t need to if my iPhone is part of number of low batteries?
123
(Taras)
November 20, 2022, 8:56pm
10
It’s possible to exclude all sensor entities from a particular integration.
For example, this rejects anything that part of the Tasmota integration.
{{ states.sensor
| rejectattr('entity_id', 'in', integration_entities('tasmota'))
| select('ge', 0)
| list | count
I don’t use the mobile app so I don’t the name of the integration that represents entities from the app.
Hi
Sorry for resurrecting this old thread. But I try to replace the fixed limit of 10, to a value of a sensor.
| map('int', -1) | select('le', {{ (states('sensor.any_sensor')) }})
My suggestion is not working, gives an error.
For anyone wondering you can use the above with the integration name as ‘mobile_app’ excludes all battery sensors from devices that use the homeassistant app.
benm7
(Ben M)
January 10, 2025, 6:24am
13
I tried using this to exclude phone and laptop batteries but it doesn’t seem to work. Does this still work for you?
