Works for me I’ve used your code
Simple entities card
Node red showing count too
Hey there,
I’m trying to implement your code, but due to the fact that i wont declare an entity_id for HA to watch the sensors wont update. Is there any workaround on that? (something like entity_id: binary_sensor.*
Here is my code:
number_of_doors_open:
value_template: "{{ states.binary_sensor | selectattr('state', 'eq', 'on') | selectattr('attributes.device_class', 'eq', 'opening') | list | count | int }}"
number_of_sensors_on:
value_template: "{{ states.binary_sensor | selectattr('state', 'eq', 'on') | selectattr('attributes.device_class', 'eq', 'motion') | list | count | int }}"
It only updates once on startup and then gives me this warning:
2020-01-17 08:38:11 WARNING (MainThread) [homeassistant.components.template] Template sensor 'number_of_doors_open' has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
2020-01-17 08:38:11 WARNING (MainThread) [homeassistant.components.template] Template sensor 'number_of_sensors_on' has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
How do i address this?
You should be able to add the below to each sensor for frequent update of the sensor.
entity_id: sensor.time
And of course you need to have the time sensor
Tried with the .all statement as per the latest documentation but it didn’t work.
entity_id: binary_sensor.all
Will try with time and report back, Thanks!
It does work with sensor.time but, it does not update instantly.
It looks like it updates every minute?
Any other ideas to make it more responsive?
Yes you are right, it updates every minute as this is the frequency that the sensor.time gets updated. I’m sorry, I don’t know of any other solution except for hardcoding all the binary sensors. There is a feature request to add force_update
to template sensors.
Thanks for the answer,
Shouldn’t entity_id: binary_sensor.all
work instantly though?
Found it in the documentation of the last update:
" The automation and script configuration panels are updated to show and manage all automations/scripts. If you want to show cards in your Lovelace UI with all entities for a single domain, use the auto-entities card. If you want to target all entities in a service call, use all
as value for entity_id
Is that what it’s talking about or am I missing something?
Or does it only refer to the group.all… groups that were discontinued?
group.all_automations
group.calendar
group.all_covers
group.all_devices
group.all_fans
group.all_lights
group.all_locks
group.all_plants
group.remember_the_milk_accounts (???)
group.all_remotes
group.all_scripts
group.all_switches
group.all_vacuum_cleaners
Haven’t read the release notes for the latest release yet.
Did you try this as well?
entity_id: all
Nope, will do and let you know.
Otherwise you may find something helpful in this topic
entity_id: all
gives me error:
Invalid config for [sensor.template]: Entity ID all is an invalid entity id for dictionary value @ data['sensors']['number_of_doors_open']['entity_id']. Got 'all'
Entity ID all is an invalid entity id for dictionary value @ data['sensors']['number_of_sensors_on']['entity_id']. Got 'all'. (See ?, line ?).
Will try the format in the post you linked, although i dont think they are supposed to work with sensors (in the sense of updating automatically)
Here is how i did what i wanted to do, although something slightly different from the counting thingy:
Create groups with the device_class i want, automation to set them up on startup and a binary sensor to show them to me as safety
script:
create_group_all_motion_sensors:
- service: group.set
data_template:
object_id: "all_sensors_motion"
entities: >
{{ states.binary_sensor | selectattr('attributes.device_class','eq','motion') | map(attribute='entity_id') | join(', ') }}
create_group_all_opening_sensors:
data_template:
object_id: "all_sensors_opening"
entities: >
{{ states.binary_sensor | selectattr('attributes.device_class','eq','opening') | map(attribute='entity_id') | join(', ') }}
automation:
- alias: Startup Stuff - Notifications
- event: start
platform: homeassistant
- data:
message: HomeAssistant is up
service: telegram_bot.send_message
- alias: Create All Groups
entity_id: script.create_group_all_motion_sensors, script.create_group_all_opening_sensors
service: script.turn_on
binary_sensor:
sensors:
all_motion_sensors_off:
friendly_name: "No Motion"
value_template: "{{ is_state('group.all_sensors_motion', 'on') }}"
device_class: safety
all_doors_closed:
friendly_name: "All Doors Closed"
value_template: "{{ is_state('group.all_sensors_opening', 'on') }}"
#had to class them as safety in order to exclude them from the previous group
When at least one motion detector is on:
With a lot of help from here
Also, about the instant depiction of the counters (relevant to this thread), If one needs it updated sooner than 1 minute (by sensor.time
Glad that you got it to work and thanks for sharing your final code! Probably won’t need it, but you never know hehe
Thanks for the help buddy
@123’s input might be helpful if somebody needs the counters to update every second for example.
You can exclude them using the reject
filter. For example:
data_template:
entities: >
| reject('eq', 'binary_sensor.all_door_closed')
| join(', ') }}
Nice! thanks again buddy!
Where can i find some documentation for those operators btw? in the Jinja docs?
Nvm, found it
This template works ok:
sensors:
lichten_hue_living_count_on:
friendly_name: Aantal HUE living lampen aan
value_template: "{{ states | selectattr('entity_id', 'in', state_attr('group.lichten_hue_living', 'entity_id')) |selectattr('state','eq','on') | list | count}}"
But ofcourse, it only update the count if the group changes from off-on. If there is 1 light on, and i turn a second light on, the template is not evaluated again. I could add the sensor.time, but then it updates 1/min. How can I make it update instantaneously without explicitely defining the group members ?
You can write an automation that updates the sensor every time the group changes like this:
- alias: 'group state change update'
platform: event
event_type: state_changed
condition: template
value_template: >
{{ trigger.event.data.entity_id in state_attr('group.lichten_hue_living','entity_id') }}
service: homeassistant.update_entity
entity_id:
- sensor.lichten_hue_living_count_on
Working. Thanks !
I am getting this response since yesterday - and not only to device_class = door
UndefinedError: ‘homeassistant.util.read_only_dict.ReadOnlyDict object’ has no attribute ‘device_class’
on this statement in the template
{{ states.binary_sensor | selectattr('state', 'eq', 'on') | selectattr('attributes.device_class', 'eq', 'door') | list | count }}
is it only me or you also got this error?
how can this be solved
