I have lot off mqtt switch in my home. I want to count the lights on in order to notify when there are too many light on and reduct my carbon footprint (and money).
any ideas on how to get the number of entityes in status on?
TNK
MArco
TNK
MArco
Try this:
{{ states.switch|selectattr('state','equalto','on')|list|length }}
OK, Work fineâŚ
thanks a lot
in â/home/homeassistant/.homeassistant/sensors.yamlâ, line 152, column 9
expected , but found ââ
Hey, the script works fine, but the counter always stays at its initial value and doesnât update when I turn lights on. What am I doing wrong?
How are you using it?
It wonât ever update unless you list out all entity ids in the entity_id field for a template sensor. Itâs an unfortunate requirement when using template devices. They need entities to know when to update.
okay, so thatâs how it works now, thanks a lot.
do i have to list all entities individually, or is there also a possibility to specify a group?
You âshouldâ be fine with the group but itâs easier just to test it and see.
Alternatively (and less elegantly) you could just have it update on a time pattern. Though that would infer it would mostly be out of date.
I always specify them all individually.
Place this into the template editor
{%- for s in states.switch %}
- {{ s.entity_id }}
{%- endfor %}
This is how I have my sensor configured to count my lights (or switches, or doorsensors, orâŚ):
sensors:
current_lights_on:
friendly_name: Lights at this moment
unit_of_measurement: 'on'
value_template: >
{% set total = 0 %}
{% if is_state('light.eetkamer', 'on') %}
{% set total = total + 1 %}
{% endif %}
{% if is_state('light.slaapkamer', 'on') %}
{% endif %}
{% if is_state('light.voortuin', 'on') %}
{% endif %}
{{total}}
And ofcourse itâs simple to make a notification-automation when the value is too high⌠Something like:
- alias: Waytoomanylights
- platform: numeric_state
entity_id: sensor.current_lights_on
above: 5
- service: notify.global_notify
data_template:
message: 'Maybe it's time to turn off some lights.'
title: Turn off some lights!
you can optimize that
value_template: >
{% set lights = [
states.light.eetkamer,
states.light.slaapkamer,
states.light.voortuin,
{{ lights | selectattr('state','eq','on') | list | count }}
Then to add a light, all you need to do is add to the list. No need for a huge if statement
Hi all
Jumping in here, hoping to get help.
Iâve tried to use your config, Petro. But cannot get my counter to work. I get back â0â lights on.
Using hass.io on RPI4
My config looks like this (Iâve listed all my lights, but just show 2 here)
sensors:
number_of_lights_on:
value_template: >
{% set light = [
states.light.bad_1,
states.light.walk_in_spot_4,
Can you help me?
Thanks in advance
PS. This is my first post, hope I did it right.
change to
{% set lights = [
Thanks a lot!!
And thanks for the fast reply, well spotted
I funny how you can go blind on your own codeâŚ
The solution by @petro works great, but I would like to extend it somehow.
Apart from counting the lights on, I would like to also have an overview of all lights that are off. I currently do this by copying the same template code in a markdown lovelace card, but omitting the | count part and iterating over all lights.
However, could this be done using a single sensor (that counts the number of lights on, but also stores the actual lights in an attribute)? This way I wonât have to define the same array (lights) in two different places?
Many thanks in advance!
you can make a attribute template. But you may not be able to use it in other areas of your template sensor. It really depends on when it gets updated, i.e. do attributes resolve templates prior to value_templates? I donât know the answer to this.
Hereâs one way:
sensors:
lights_on_off:
value_template: >
{% set lights = [ states.light.first,
states.light.second,
states.light.third,
states.light.etc ] %}
{{ lights | selectattr('state','eq','on') | list | count }} {{ lights | selectattr('state','eq','off') | list | count }}
The state of this Template Sensor will be something like:
3 12
which means 3 lights are on and 12 lights are off.
If you want to extract the number of lights that are off (12) you would use a template like this:
{{ states('sensor.lights_on_off').split()[1] }}
Change the 1 to 0 to get the number of lights that are on.
If you to get fancy, you can add the total number of lights so the sensorâs state looks something like this:
3 12 17
That would mean 3 are on, 12 are off, 17 in total, and 17 - (3+12) = 2 are neither on or off (possibly unknown or unavailable).
Thanks for this answer, gives some ideas!
But what I am looking for is a way to return a list of entities in the sensor, e.g. the output of this:
{{lights | selectattr('state','eq','on') | list}}
I currently use this code in my frontend (markdown card), but the same variable lights is also used in the sensor configuration for counting the number of lights that are active. It works, but whenever I want to change this variable (e.g. adding a new light), I need to add it in 2 places (sensor and frontend).
Therefore, I was wondering if I could add the current entities (or just their names) into the sensor, or does anyone know another trick for not having to define the same variable twice? Or should I just get rid of the sensor and do everything in the markdown (frontend) card?
Yes, as I said, youâ have to use it as an attribute inside a sensor. If you want it to properly push updates youâll need to jump through hoops, below is my initial attempt (I have not tried it, youâre welcome to). You can create a âhelperâ entity, then a series of template sensors off it. In the helper, youâll have to declare the list a few times but it every time outside that helper entity, you should be good.
sensors:
light_helper:
value_template: >
{%- set lights = [ states.light.first,
states.light.third ] %}
{%- set ns = namespace(last_updated=[]) %}
{%- for light in lights %}
{%- set ns.last_updated = ns.last_updated + [ as_timestamp(light.last_updated) ] %}
{%- endfor %}
{{ ns.last_updated | max | timestamp_custom('%Y-%m-%dT%H:%M:%S.%f+00:00', False) }}
entity_id: light.first, light.second, light.third
device_class: timestamp
attribute_templates:
lights: >
{{ lights }}
Now create a separate template sensor and get whatever you want.
lights_on:
value_template: >
{{ state_attr('sensor.light_helper', 'lights') | selectattr('state','eq','on') | list | count }}
