Hi folks, I have like 60 ish switches, every one with 3 outlets and located in different areas around my house. I’m working with minimalist UI, which provides “chips”. I would like to use one of those to know how many switches I have turned on, but I0m not sure as I cold not find anything on the web.
I just included the sensors yaml in my config file, as showed below:
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
frontend:
themes: !include_dir_merge_named themes
While I was searching, I also found that I needed to create a group inside my configuration.yaml file, so I did it as stated below:
group:
luces_cuartoprincipal:
name: Luces cuarto principal
entities:
- switch.sonoff_1000f47d9a_1
- switch.sonoff_1000f47d9a_2
- switch.sonoff_1000f47d9a_3
- switch.sonoff_1000e98e6c_1
- switch.sonoff_1000e98e6c_2
- switch.sonoff_1000950537_1
- switch.sonoff_1000950537_2
- switch.sonoff_100095020c_1
- switch.sonoff_100095020c_2
And inside my sensors.yaml file I tried to create a sensor platform, But I’m not sure it would work as it uses a lot of code I found in certain topics in here, it looks like this:
sensors:
lucesencendidas_cuartoprincipal:
entity_id:
value_template: >
{% set switches = [
states.switch.sonoff_1000f47d9a_1,
states.switch.sonoff_1000f47d9a_2,
states.switch.sonoff_1000f47d9a_3,
states.switch.sonoff_1000e98e6c_1,
states.switch.sonoff_1000e98e6c_2,
states.switch.sonoff_1000950537_1,
states.switch.sonoff_1000950537_2,
states.switch.sonoff_100095020c_1,
states.switch.sonoff_100095020c_2,
I need a little help creating this sensor, as I wanted to show how many lights are located in certain areas. Thanks in advance!
