Couple of minor Zigbee2mqtt map issues
Hopefully a couple of simple questions regarding the Z2M Map screen in the UI:-
Firstly when accessing the map it takes my system 10 to 15 minutes to produce the map rather than the 10s - 2m stated on screen - it all works fine but just takes it’s time.
Secondly I always get some end devices on the map (not always the same ones) that do not appear to be connected to anything else (they are not greyed out) - I assume this is because they are asleep when the map is produced ? - They work fine, I’ve just no idea which router they are using.
100 devices in the mesh. All FW’s are latest versions. ZZH 2652 USB Coordinator.
What machine are you running on ?
On my Pi4, it took much longer to generate than on my x86 machine now.
Have you tried looking in the log during the map generation, that might give some insight!
The map generation seems to work by contacting each device one at a time, so if endpoints are asleep, that would slow things down.
Having devices in your Z2M configuration that are no longer present will also take a long time since it has to time out for each device that has been removed.
This is my machine during a migration. Every item on the right is bad and causes the map generation to take substantially longer. Some of the devices on the right are migrated (even though some of them seem to be connected), and some of them are unreachable, like the temperature sensor that has not been migrated but can’t reach any device anymore.
(Only with the one BWS sensor directly connected to the system, on the right is correct :stuck_out_tongue: ).
this all causes map generation to take quite long
