Couple questions
1 How can I get the conversation mic into hadashboard, the one you see by default in hassio?
2 Is it possible to wrap multiple widgets in a wrapped? I want to use this to put widgets into a visual container to group them into categories.
3 Can hadashboard show a normal hassio group with toggle? For instance a light group or switch group in the hassio formatting and visual style?
4 is there a long press function? I would like to be able to click a widget for let’s say the living room lights, but if I long press I want it to show a living room popup that contains more info about the living room or shows a color picker to choose the light color etc.
Can someone point me in the right direction? I’m reading through the docs, maybe I missed something?
  1. i have no idea what that is.
  2. not possible without creating custom widgets
  3. no, not without creating custom widgets
  4. no, not without creating custom widgets
I don’t know if I’m reading this correctly but it looks like you’re recommending custom widgets :wink:
The conversation mic appears in the top right corner of home assistant and let’s you voice control home assistant, it’s added by placing
Conversation:
In the normal config.yaml
voice control is not possible with the dashboard.
and i dont recommend custom widgets, but the options that you ask are not there.
in theory they are probably possible, but not easy to create. if its possible it can only be done by creating it yourself.
