giovanni
(Giovanni)
November 19, 2021, 12:59pm
1
I have a room with two radiators. Each of them mounts a z-wave thermostatic valve, but it makes no sense to me to have different control over the two valves. I have tried the following automation in order to couple the two temperatures: as one is changed the other follows, but it just seems not to work at all. What am I doing wrong?
- id: '1613419540106'
alias: Livingroom radiators coupling
- platform: state
entity_id: climate.radiator_livingroom_sx,climate.radiator_livingroom_dx
attribute: temperature
- service: climate.set_temperature
entity_id: '{{ thermostats|reject(''eq'', trigger.entity_id)|list }}'
temperature: '{{ trigger.to_state.attributes.temperature }}'
I have also tried the following unsuccessfully:
- id: '1637327773954'
alias: Livingroom radiator master sx
description: ''
- platform: state
condition: []
entity_id: climate.radiator_livingroom_dx
temperature: '{{ states(''climate.radiator_livingroom_sx'', ''temperature'')
| float }}'
mode: single
fedot
November 20, 2021, 11:20am
2
Creating a group doesn’t work?
giovanni
(Giovanni)
November 20, 2021, 12:16pm
3
Yes, I tried that but it did not work
fedot
November 20, 2021, 12:21pm
4
What exactly doesn’t work?
If you create a group with the two entities, it should create a group
entity you then interact with
group:
climate:
entities:
- climate.radiator_livingroom_sx
- climate.radiator_livingroom_dx
giovanni
(Giovanni)
November 20, 2021, 1:07pm
5
Thermostat lovelace card doesn’t allow to put groups as entities.
giovanni
(Giovanni)
November 21, 2021, 9:43am
6
I tried the following approach throught an automation but it doesnt work, what am I doing wrong?
Here’s my code:
description: ''
- platform: state
condition: []
| float }}'
mode: single
mirekmal
(Mirek Malinowski)
November 21, 2021, 11:29am
7
giovanni:
What Template Editor shows you as result of template you used as target setpoint temperature? To me it looks incorrect, so automation does not work…
{{ states(''climate.radiator_livingroom_sx'', ''temperature'') | float }}
I’d use something like:
{{ states.climate.radiator_livingroom_sx.attributes.temperature | float }}
giovanni
(Giovanni)
November 21, 2021, 12:12pm
8
Nothing…
Maybe I have to wait for the thermostatic valve to wake up? Or on lovelace it shows the set temperature regardless of what is currently shown on the thermostatic valve?
giovanni
(Giovanni)
November 21, 2021, 12:14pm
9
This is the result of the trace of the automation, if usefule
Executed: November 21, 2021, 1:12:49 PM
Result:
params:
domain: climate
service: set_temperature
service_data:
temperature:
'[object Object]': null
entity_id:
entity_id:
running_script: false
limit: 10
mirekmal
(Mirek Malinowski)
November 21, 2021, 12:58pm
10
Tested on my configuaration and this code worked for me:
alias: bedroom sync
description: ''
- platform: state
entity_id: climate.valve_mirek
condition: []
entity_id: climate.valve_bedroom
temperature: >
{{ state_attr('climate.valve_mirek', 'temperature') | float }}
mode: single
After changing target temp on climate.valve_mirek it took ~30 seconds to get this reflected on climate.valve_bedroom.
