basically I have some curtains that open vertically and the current cover arrow icons makes no sense.
how do I change the arrows to look like this? Or something better?
Guessing a custom card might be needed.
I use https://github.com/benct/lovelace-multiple-entity-row in a handful of places and it works great!
For example:
You can pretty much have whatever you want with this
You can change the device_class
to awning, door or gate. then you get beter icons imo.
More info on how to change the device class (which is about the easiest way to modify action buttons):
If you notice that the modified device_class jumps back to its original settings (and the action buttons revert to default), then some of the above suggested card collections may be a better option.
At your service, hoping this might help someone on their way.
