Cover automation failing - Entity {{ cover_e }} is neither a valid entity ID nor a valid UUID for dictionary value @ data
Hello there,
I have the following automation that I have created/adapted it from previous inspirations that I have seen around here, although, I’m not trying to make a newer version, and having an issue that I’m not getting.
I’m on 2024.9.0.
Could it be due to the new changes over the service/action?
Old working automation
blueprint:
  name: Sun Protection vAug24
  description: close cover when sun is shining and open when stops
  domain: automation
  input:
    cover_entity:
      selector:
        entity:
          domain: cover
    sun_position_start:
      name: sun azimuth position start
      description: Sun azimuth. when sun is below this value, shutter could be triggered
      selector:
        entity:
          domain: input_number
    sun_position_end:
      name: sun azimuth position end
      description: Sun azimuth. when sun is over this value, shutter could be triggered
      selector:
        entity:
    sun_elevation_start:
      name: sun elevation to start
      description: Sun elevation. when sun is over this value, shutter could be triggered
      selector:
        entity:
    weather:
      selector:
        entity:
          domain: weather
      selector:
        entity:
          domain: sensor
    outdoor_temp_1:
      name: Pos1 - Outdoor temperature (Low)
      description: Temperature above which the shutters will close
      selector:
        entity:
    outdoor_temp_2:
      name: Pos2 - Outdoor temperature (Medium)
      description: Second temperature threshold above which the shutters will close
      selector:
        entity:
    outdoor_temp_3:
      name: Pos3 - Outdoor temperature (High)
      description: Third temperature threshold above which the shutters will close
      selector:
        entity:
    alarm_to_override:
      name: Alarm that will override Sunrise
      description: Automation will only run when time is after than this input_datetime value.
      default:
      selector:
        entity:
          domain: input_datetime
    alarm_weekend_to_override:
      name: Weekend Alarm that will override Sunrise
      default:
      selector:
        entity:
    home_temperature:
      description: Automation will compare the outside temperature with the inside to only open if it is lower.
      default:
      selector:
        entity:
          domain: sensor
    homews_isinstalled:
      name:  Home WS Installed
      description: Validator of the status
      default:
      selector:
        entity:
          domain: input_boolean
    homews_temperature:
      name:  Outside Temperature to be based on Home Weather Station
      default:
      selector:
        entity:
          domain: sensor
    homews_rainrate:
      name:  Rain Rate to be based on Home Weather Station
      description: Rain Rate to be based on Home Weather Station
      default:
      selector:
        entity:
          domain: sensor
    rainrate_pouring:
      name:  Pouring Rain Rate
      description: Rain Rate to be compared with
      default:
      selector:
        entity:
    rainrate_rainy:
      name:  Rainy Rain Rate
      default:
      selector:
        entity:
    nelsonws_temperature:
      name:  Outside Temperature to be based on Nelson's Weather Station
      default:
      selector:
        entity:
          domain: sensor
    nelsonws_rainrate:
      name: Rain Rate to be based on Nelson's Weather Station
      default:
      selector:
        entity:
          domain: sensor
variables:
    cover_e: !input cover_entity
    var_e: "{{ 'var.' + cover_e[6:] }}"
    protection_begin: !input sun_position_start
    protection_end: !input sun_position_end
    elevation_begin: !input sun_elevation_start
    outdoor_temp: !input outdoor_temp_1
    outdoor_temp_2: !input outdoor_temp_2
    outdoor_temp_3: !input outdoor_temp_3
    intermediate_position: "{{ 'var.intermediate_position'}}"
    fully_closed_position: "{{ 'var.fully_closed_position'}}"
    mid_afternoon_position: "{{ 'var.mid_afternoon_position'}}"
    open_position_rainy: "{{ 'var.open_position_rainy'}}"
    open_position: "{{ 'var.open_position'}}"
    weather_service: !input weather
    alarm_to_override: !input alarm_to_override
    alarm_weekend_to_override: !input alarm_weekend_to_override
    home_temperature: !input home_temperature
    sensor: !input sensor
    homews_isinstalled: !input homews_isinstalled
    homews_temperature: !input homews_temperature
    homews_rainrate: !input homews_rainrate
    rainrate_pouring: !input rainrate_pouring
    rainrate_rainy: !input rainrate_rainy
    nelsonws_temperature: !input nelsonws_temperature
    nelsonws_rainrate: !input nelsonws_rainrate
mode: parallel
trace:
    stored_traces: 300
  - platform: time_pattern
    minutes: "/5"
condition:
  - condition: or
    conditions:
      - condition: template
        value_template: >
          {% set current_time = now().strftime("%H:%M")  %}
          {{ current_time > states[alarm_to_override].state  and  (now().weekday() in (1,2,3,4,5)) }}
        value_template: >
          {{ current_time > states[alarm_weekend_to_override].state  and  (now().weekday() in (0,6))}}
  - condition: sun
    before: sunset
    after: sunrise
  - choose:
      # close cover - third temperature threshold
      - conditions:
            value_template: "{{- is_state('input_boolean.cover_manage_cover_with_sun', 'on') -}}"
            value_template: "{{ states(var_e) != '1' }}"
            value_template: "{{ state_attr('sun.sun', 'azimuth') > states(protection_begin) |float and state_attr('sun.sun', 'azimuth') < states(protection_end) |float and state_attr('sun.sun', 'elevation') > states(elevation_begin) |float }}"
          - condition: or
            conditions:
                value_template: "{{ state_attr(cover_e, 'current_position') == states(open_position) |float }}"
                value_template: "{{ state_attr(cover_e, 'current_position') == states(intermediate_position) |float }}"
                value_template: "{{ state_attr(cover_e, 'current_position') == states(fully_closed_position) |float }}"
                value_template: "{{ state_attr(cover_e, 'current_position') == states(mid_afternoon_position) |float }}"
          - condition: or
            conditions:
                value_template: "{{ states(weather_service) == 'partlycloudy' }}"
                value_template: "{{ states(weather_service) == 'sunny' }}"
            value_template: >-
                {{ (is_state(homews_isinstalled , 'on') and states(outdoor_temp_3) |int > states(home_temperature) |int and states(homews_temperature) |int >= states(outdoor_temp_3) |int )
                or (state_attr(weather_service, 'temperature') != None and is_state(homews_isinstalled , 'off') and states(outdoor_temp_3) |int > states(home_temperature) |int and state_attr(weather_service, 'temperature') |int >= states(outdoor_temp_3) |int) }}
        sequence:
          - data_template:
              entity_id: "{{ cover_e }}"
              position: "{{ states(fully_closed_position) |float }}"
            service: cover.set_cover_position
      # close cover - second temperature threshold
      - conditions:
          - condition: or
            conditions:
          - condition: or
            conditions:
            value_template: "{{ state_attr(weather_service, 'temperature') != None and is_state(homews_isinstalled , 'off') and states(outdoor_temp_2) |int > states(home_temperature) |int and states(outdoor_temp_3) |int <= states(home_temperature) |int }}"
        sequence:
          - data_template:
              position: "{{ states(intermediate_position) |float }}"
      # close cover - first temperature threshold
      - conditions:
          - condition: or
            conditions:
          - condition: or
            conditions:
            value_template: >-
              {{ (is_state(homews_isinstalled , 'on') and states(outdoor_temp_3) |int > states(home_temperature) |int and states(homews_temperature) |int >= states(outdoor_temp_3) |int)
              or (state_attr(weather_service, 'temperature') != None and states(outdoor_temp_3) |int > states(home_temperature) |int and state_attr(weather_service, 'temperature') |int >= states(outdoor_temp_3) |int) }}
        sequence:
          - data_template:
              position: "{{ states(mid_afternoon_position) |float }}"
      # set cover if rainy
      - conditions:
          - condition: sun
            before: sunset
            after: sunrise
       #   - condition: template
       #     value_template: "{{ state_attr('sun.sun', 'azimuth') > states(protection_begin) |float and state_attr('sun.sun', 'azimuth') < states(protection_end) |float and state_attr('sun.sun', 'elevation') > states(elevation_begin) |float }}"
            value_template: >-
              {{ states(weather_service) == 'rainy' and ( ( is_state(homews_isinstalled , 'on') and states(homews_rainrate) | float >= states(rainrate_rainy) | float and states(homews_rainrate) | float < states(rainrate_pouring) | float)  or  is_state(homews_isinstalled , 'off') ) }}"
        sequence:
          - data_template:
              position: "{{ states(open_position_rainy) |float }}"
      # set cover if pouring
      - conditions:
          - condition: sun
            before: sunset
            after: sunrise
            value_template: "{{ states(weather_service) == 'pouring' and ( ( is_state(homews_isinstalled , 'on') and states(homews_rainrate) | float >= states(rainrate_pouring) | float )  or  is_state(homews_isinstalled , 'off') ) }} "
        sequence:
          - data_template:
      # open cover before sunset
      - conditions:
          - condition: sun
            before: sunset
            after: sunrise
            value_template: "{{ (state_attr('sun.sun', 'azimuth') < states(protection_begin) |float or state_attr('sun.sun', 'azimuth') > states(protection_end) |float or  state_attr('sun.sun', 'elevation') < states(elevation_begin) |float) }}"
          - condition: or
            conditions:
            value_template: >-
              {{ (is_state(homews_isinstalled , 'on') and states(homews_temperature) |int < states(home_temperature) |int)
              or (state_attr(weather_service, 'temperature') != None and state_attr(weather_service, 'temperature') |int < states(home_temperature) |int)
              or (state_attr(weather_service, 'temperature') == None and states(outdoor_temp) |int <= states(home_temperature) |int) }}"
        sequence:
          - data_template:
      # open cover
      - conditions:
          - condition: sun
            before: sunset
            after: sunrise
          - condition: or
            conditions:
            value_template: "{{ (state_attr(weather_service, 'temperature') != None and state_attr(weather_service, 'temperature') |int < states(home_temperature) |int) or (state_attr(weather_service, 'temperature') == None and states(outdoor_temp) |int <= states(home_temperature) |int) }}"
        sequence:
          - data_template:
              position: "{{ states(open_position) |float }}"
Here is the new version, and the error I’m getting.
New not working automation
blueprint:
  name: Sun Protection vAug24 Enhanced
  description: Enhanced blueprint to control cover based on sun position,
    temperature, weather conditions, and seasonal adjustments.
  domain: automation
  input:
    cover_entity:
      selector:
        entity:
          domain: cover
    sun_position_start:
      name: Sun Azimuth Start
      description: Start azimuth value to trigger cover control
      selector:
        entity:
    sun_position_end:
      name: Sun Azimuth End
      description: End azimuth value to trigger cover control
      selector:
        entity:
      name: Sun Elevation Start
      description: Minimum elevation to trigger cover control
      selector:
        entity:
    weather:
      selector:
        entity:
          domain: weather
      selector:
        entity:
          domain: sensor
    outdoor_temp_low:
      name: Low Temperature Threshold
      description: Shutters will close if outdoor temp is above this value
      selector:
        entity:
    outdoor_temp_medium:
      name: Medium Temperature Threshold
      description: Second temperature threshold for cover control
      selector:
        entity:
    outdoor_temp_high:
      name: High Temperature Threshold
      description: Third temperature threshold for cover control
      selector:
        entity:
    alarm_to_override:
      name: Alarm Override for Weekdays
      description: Time after which automation is active on weekdays
      selector:
        entity:
      name: Alarm Override for Weekends
      description: Time after which automation is active on weekends
      selector:
        entity:
    home_temperature:
      name: Indoor Temperature Sensor
      description: Sensor to compare indoor and outdoor temperature
      selector:
        entity:
          domain: sensor
    homews_isinstalled:
      name: Home Weather Station Installed
      description: Boolean to indicate if home weather station is available
      selector:
        entity:
    homews_temperature:
      name: Home Weather Station Outdoor Temperature
      selector:
        entity:
          domain: sensor
    homews_rainrate:
      name: Home Weather Station Rain Rate
      selector:
        entity:
          domain: sensor
    rainrate_pouring:
      name: Pouring Rain Rate Threshold
      selector:
        entity:
    rainrate_rainy:
      name: Rainy Rain Rate Threshold
      selector:
        entity:
    season_selector:
      description: Select the current season to adjust thresholds accordingly
      selector:
        entity:
          domain: sensor
    light_sensor:
      name: Optional Light Sensor
      description: (Optional) Light sensor to measure ambient light levels
      selector:
        entity:
          domain: sensor
      default: none
variables:
  sun_azimuth: "{{ state_attr('sun.sun', 'azimuth') | float }}"
  sun_elevation: "{{ state_attr('sun.sun', 'elevation') | float }}"
  is_sunny: "{{ states(weather) in ['partlycloudy', 'sunny'] }}"
  is_rainy: "{{ states(weather) == 'rainy' }}"
  is_pouring: "{{ states(weather) == 'pouring' }}"
  indoor_temp: "{{ states[home_temperature].state | float }}"
  outdoor_temp: |-
    {% if is_state('input_boolean.homews_isinstalled', 'on') %}
      {{ states[homews_temperature].state | float }}
    {% else %}
      {{ state_attr(weather, 'temperature') | float }}
    {% endif %}
  rain_rate: |-
      {{ states[homews_rainrate].state | float }}
    {% else %}
      0
    {% endif %}
  current_season: "{{ states(season_selector) }}"
  ambient_light: |-
    {% if light_sensor != 'none' and states(light_sensor) %}
      {{ states(light_sensor).state | float }}
    {% else %}
      1000  # Default value if no light sensor is provided
    {% endif %}
    minutes: /15
    value_template: "{{ sun_elevation > states.sun_elevation_start | float }}"
  - platform: state
    entity_id:
      - weather
  - platform: state
    entity_id: season_selector
condition:
  - condition: or
    conditions:
        value_template: '{% set current_time = now().strftime("%H:%M") %} {{
          current_time > states[alarm_to_override].state and now().weekday() in
          (1, 2, 3, 4, 5) }}'
          now().weekday() in (0, 6) }}'
  - condition: sun
    before: sunset
    after: sunrise
  - variables:
      adjusted_outdoor_temp_low: >-
        {% if current_season == 'summer' %}
          {{ states.outdoor_temp_low | float * 1.1 }}  # Example: Increase threshold by 10%
        {% else %}
          {{ states.outdoor_temp_low | float }}
        {% endif %}
      adjusted_outdoor_temp_medium: |-
          {{ states.outdoor_temp_medium | float * 1.1 }}
        {% else %}
          {{ states.outdoor_temp_medium | float }}
        {% endif %}
      adjusted_outdoor_temp_high: |-
          {{ states.outdoor_temp_high | float * 1.1 }}
        {% else %}
          {{ states.outdoor_temp_high | float }}
        {% endif %}
      light_level_threshold: 500
  - choose:
      - conditions:
            value_template: "{{ sun_azimuth > states.sun_position_start | float and
              sun_azimuth < states.sun_position_end | float and sun_elevation >
            value_template: "{{ is_sunny }}"
            value_template: "{{ outdoor_temp >= adjusted_outdoor_temp_high and outdoor_temp
              > indoor_temp }}"
            value_template: "{{ ambient_light > light_level_threshold }}"
        sequence:
          - action: cover.set_cover_position
            data_template:
              position: "{{ states['var.fully_closed_position'] | float }}"
      - conditions:
            value_template: "{{ outdoor_temp >= adjusted_outdoor_temp_medium and
              outdoor_temp < adjusted_outdoor_temp_high and outdoor_temp >
              indoor_temp }}"
        sequence:
            data_template:
              position: "{{ states['var.intermediate_position'] | float }}"
      - conditions:
            value_template: "{{ outdoor_temp >= adjusted_outdoor_temp_low and outdoor_temp <
              adjusted_outdoor_temp_medium and outdoor_temp > indoor_temp }}"
        sequence:
            data_template:
              position: "{{ states['var.mid_afternoon_position'] | float }}"
      - conditions:
            value_template: "{{ is_rainy and rain_rate >= states.rainrate_rainy | float and
              rain_rate < states.rainrate_pouring | float }}"
        sequence:
            data_template:
              position: "{{ states['var.open_position_rainy'] | float }}"
      - conditions:
            value_template: "{{ is_pouring and rain_rate >= states.rainrate_pouring | float }}"
        sequence:
            data_template:
      - conditions:
            value_template: "{{ (sun_azimuth < states.sun_position_start | float or
              sun_azimuth > states.sun_position_end | float or sun_elevation <
              states.sun_elevation_start | float) }}"
            value_template: "{{ ambient_light < light_level_threshold }}"
            value_template: "{{ (outdoor_temp < indoor_temp and outdoor_temp <=
              states.outdoor_temp_low | float) }}"
        sequence:
            data_template:
              position: "{{ states['var.open_position'] | float }}"
  - default:
        data_template:
  - choose:
      - conditions:
          - condition: state
            state: closed
        sequence:
          - action: logbook.log
            data_template:
              name: Cover Automation
              message: Cover {{ cover_e }} closed due to high temperature or rain.
      - conditions:
          - condition: state
            state: open
        sequence:
            data_template:
              message: Cover {{ cover_e }} opened as conditions normalized.
  - action: notify.notify
    data_template:
      title: Cover Automation Update
      message: Cover {{ cover_e }} moved to position {{ state_attr(cover_e, 'current_position') }}.
Any hints?
Cheers
HI David,
You have several of these where you have a template in a message string. I may be wrong but I think they need to be quoted. At least I quote mine. (The whole string in my case.)
While quoting templates is good practice, technically it’s not required if the message begins with a string.
Acceptible:
message: The time is {{ now() }}
Not acceptible (yaml error):
message: {{ now() }} is the time.
This is because the opening brace in the first character is telling yaml that what’s coming is an object, and not a string, so the quotes are required. When there are string characters before the opening brace, it’s just all treated as string implicitly.
But generally it’s just good habit to always quote so you don’t forget.
EDIT: Actually it even looks like the frontend UI editor would actively remove the quotes here even if you did add them. Once you save and return they would be gone. So I guess adding them here would be pointless.
          - condition: state
            state: open
State condition does not accept entity_id to be templated. Use a template condition instead.
Thank you both, @karwosts & @Sir_Goodenough . Well, it seems that I have multiple issues going on. I tried to simplify a bunch of things, and even running my new version through ChatGPT to validate it, but it isn’t that simple. :sweat_smile:
E.g.,
So, yeah, I’ll be rewriting it, and then provide an update here.
