Probably won’t be able to help, but I’m also just curious: can you share screenshots of the buttons when the cover is all the way open, half open, and all the way closed? As well as describe the difference between what is being shown and what you expect?
I come to the following conclusion:
the buttons of the template cover do no work good.
the slider works but I think it is not working on 0 and 100. thus only 1-99
using the buttons in the template cover does nothing… in the template cover. the realcover does move opposite though.
When I open the cover with the template cover it closed the realcover (as expected) but the slider of the templatecover does not change?
Why the heck is this so frikking complex? Just to turn around up and down in a cover!?!
You’re inverting hardware functionality, it’s going to be complex. If you didn’t have the slider, this would have been already done.
Add the value template back and set it to
value_template: "{{ (100 - state_attr('cover.realcover_r', 'position')) > 95 }}"
As for the moving of the slider position, that will only update if your cover.realcover_r updates the position when you open and close it.
then the template cover in unavailable
Logger: homeassistant.helpers.event
Source: helpers/template.py:400
First occurred: 18:38:52 (2 occurrences)
Last logged: 18:38:52
Error while processing template: Template("{{ (100 - state_attr('cover.realcover_r', 'position')) > 95 }}")
Error while processing template: Template("{{ 100 - state_attr('cover.realcover_r', 'position') }}")
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 398, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1698, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 925, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for -: 'int' and 'NoneType'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 514, in async_render_to_info
render_info._result = self.async_render(variables, strict=strict, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 400, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: unsupported operand type(s) for -: 'int' and 'NoneType'
look in your logs and look for an error, I’m assuming you messed up the indentation and the error will point that out. Or you possibly deleted a character somewhere.
if the template itself is erroring, then safety needs to be built in
value_template: "{{ (100 - state_attr('cover.realcover_r', 'position') | int(100)) > 95 }}"
First occurred: 18:47:15 (1 occurrences)
Last logged: 18:47:15
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:73
Integration: Template (documentation, issues)
TemplateError('TypeError: unsupported operand type(s) for -: 'int' and 'NoneType'') while processing template 'Template("{{ 100 - state_attr('cover.realcover_r', 'position') }}")' for attribute '_position' in entity 'cover.r_reversed'
that error is referring to the other template, which is why the position was never getting updated when you turn it on or off.
change to
position_template: "{{ 100 - state_attr('cover.realcover_r', 'position') | int(100) }}"
No more error.
Now template cover buttons dont work.
Ah… think the buttons do work but slider and buttons in template cover is not updated…
that means your cover that you’re inverting does not have a slider… Does it have a slider?
post a picture of the cover in dev tools → states with the slider all the way open, and all the way closed. Make sure to include the attributes. Not the template slider, the slider you are trying to invert.
should “position” be “current_postition” in the code?
Yes if that’s the name of the attribute
I think that’s it…
The working code for the archive:
covers:
cover_r_reversed:
friendly_name: "Cover R Reversed"
position_template: "{{ 100 - state_attr('cover.realcover_r', 'current_position') | int(100) }}"
value_template: "{{ (100 - state_attr('cover.realcover_r', 'current_position') | int(100)) > 95 }}"
open_cover:
service: cover.close_cover
data: {}
entity_id: cover.realcover_r
close_cover:
service: cover.open_cover
data: {}
stop_cover:
service: cover.stop_cover
data: {}
set_cover_position:
service: cover.set_cover_position
position: "{{100-position}}"
icon_template: >-
{% if is_state('cover.realcover_r', 'closed') %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
one more question about this… whats the 95 in value_template: "{{ (100 - state_attr('cover.realcover_r', 'current_position') | int(100)) > 95 }}" for?
Well, anything over 95 on the slider will consider it open
EDIT: You can remove that now probably. I added it based on your previous comments but it turns out the attribute was just wrong.
liket his:
value_template: "{{ (100 - state_attr('cover.realcover_r', 'current_position') | int(100)) }}"
no remove the whole line
covers:
cover_r_reversed:
open_cover:
data: {}
close_cover:
data: {}
stop_cover:
data: {}
set_cover_position:
icon_template: >-
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
